89 cam and motor swap need some advice!
Old 08-23-2014, 12:11 PM
brandon mauldin's Avatar
brandon mauldin
brandon mauldin is offline
I thought the stock ones were supposed to work too but they are deff short idk what the deal is
Old 08-23-2014, 12:49 PM
Conanski's Avatar
Conanski
Conanski is offline
Yeah that is strange, I got the same cam(XE264HR-14) in a 5.0 roller with stock heads and the stock pushrods were the right length. How much too short are they? And did those pushrods come with that motor?
Old 08-23-2014, 12:54 PM
brandon mauldin
Yes the push rods were the same ones that were in it and I never measured them but they are deff shorter than before. I could spin them before but now I can pretty much wiggle them around. There's not much difference in the 12 that I have and the 14 you have right?
Old 08-23-2014, 01:02 PM
Conanski's Avatar
Conanski
Conanski is offline
No the cams are identical except for the lobe separation angle. You need to make sure the lifters aren't collapsed when testing for pushrod length, one simple way to do that is to dismantle one(be careful there is a spring inside) and replace the guts with washers so that the plunger cannot collapse when the rocker is torqued down. That simulates full oil pressure so you can get an accurate measurement. It is possible you need slightly longer pushrods.. different heads so anything is possible.
Old 08-23-2014, 01:59 PM
brandon mauldin
Well idk the same heads and same push rods worked fine with my stock cam... Maybe I was just in a hurry and put somthin back together wrong idk I'll look at it again when I get home
Old 08-23-2014, 02:37 PM
brandon mauldin
You recommend any good springs?
Old 08-23-2014, 03:06 PM
brandon mauldin
I think I may have found the problem, the cam I have the (xe264hr-12) has a lift off .544 the one you have (xe264hr-14) has a lift of .512.. Is that why your stock push rods worked and mine didn't..?
Old 08-23-2014, 03:47 PM
Conanski's Avatar
Conanski
Conanski is offline
No and no. Both of these cams produce 0.512" lift with 1.6 rockers and 0.544" lift with 1.7 rockers, and that has no effect on pushrod length.
Old 08-23-2014, 03:55 PM
brandon mauldin
Hmmm this beats the **** outta me lol
Old 08-24-2014, 01:26 AM
brandon mauldin
Hey man when I got home I decided to take a drill and old distributer gear and pump up the oil in the motor, when I started to pump it all the lose push rods tightened up and actually seemed like they were where they needed to be! But the moment I stopped pumping the oil the pushrods got really lose again...?
My4Fordtrucks
49
11-06-2017 07:59 AM
80'BUB
05-31-2017 06:30 PM
CLIFF1989
03-07-2010 04:51 PM
jmjsfamily
04-01-2008 08:07 AM
Thomsen
09-02-2005 01:38 AM
Quick Reply: 89 cam and motor swap need some advice!
