My truck smokes when started?
I have a 97 F250 7.3 power stroke I recently just bought. When I start it, it blows out alot of white smoke for 5-10 minutes after starting. I've replaced the PCM, it cut the smoking down a little and if you rev the truck up it will shoot most of it out with in a few minutes. It also smells like straight fuel, is there anything I could try?
well, it is an old diesel truck, there'll always be some smoke when cold :-)
sounds like dead glow plugs to me. my first powerstroke (the red one in my sig) smoked like a freight train when it first started ...if it started in the real cold weather. a new set of glowplugs and it started first time everytime in subzero temps and smoke was way down.
could be other things, but if its a new truck to you, GP's are a good thing to check anyway. you can ohm them out at the valve cover connectors. i believe they should all read 1.5 ohms to ground and are the outermost pins on each connector. there's quite a few threads on this though, so a quick search should get you on the right track.
good luck and welcome to FTE!
