coil B misfire
coil B misfire
I have replaced this coil 5 times and twice by my local ford dealer, and have replaces the connector once. When I replace the coil it runs fine for 10-15 miles then runs on 7 cylinders. It now runs on all 8 sometimes around around 2800-3500 rpm, anybody have any idea what it could be? Im at a loss.
This sounds like a wiring harness issue somewhere between the COP connector itself back to several leading to the PCM.
When these COP's have been replaced has anyone tested them to make sure they're actually defective or no longer working? A DC resistance test of the COP is NOT reliable FWIW.
Okay then with different brands and they're holding up so far I'm still suspecting a wiring issue.
BTW Coil B would also be called #2 which should be the second one back on the passenger side--correct?
This issue could also be asked in the appropriate Modular Motor forum whether V8 or V10. I'll bet someone there has gone through and successfully fixed this same sort of issue.
That's a new one on me too---no real idea other than to consider just a defective case? I've never opened a COP or had one fail like this so the brown oozing stuff is also a mystery to me.
What concerns me more about your engine is why there would be multiple COP failures of the same cylinder. That needs to be addressed first, or so I'd think.
Please let us know if you ever solve this odd situation.
