Y block adapted to newer upgrade trans
Old 08-11-2014, 08:35 AM
Psmith1951's Avatar
Psmith1951
Psmith1951 is offline
Has anyone been able to use their Y block motor and adapt it to a newer upgraded transmission. If so, I would like some suggestions. I would like to add an automatic with overdrive in my 1956 build. Psmith1951
Old 08-12-2014, 08:44 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
Old 08-12-2014, 10:13 AM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Here is one to connect a C4 to a Y-block. I have one on my 56 Fairlane, works very well.
The Y-Block
Old 08-12-2014, 04:17 PM
Psmith1951's Avatar
Psmith1951
Y block transmission swap
Thanks for all the information. How satisfied were you with the C4 in the 1956 Fairlane compared to before? I would like to keep my 312 Y block in my build, but I want more efficiency on the road with a later automatic trans. I have a good C6 transmission that I could use and I have access to several of the C4 transmissions. psmith1951
Old 08-12-2014, 05:10 PM
bjmayberry2
I've got a truck Flat-O but haven't got it put in yet. I also bought a car Flat-O bell housing and flex plate at a swap meet. I got the rest of the stuff from Gene at Flat-O to make it work but in order to install it in a truck you'd have to change to car motor mounts and add a transmission crossmember for the C4.
Trying to get the ole Y Block purring before I change it over to an automatic. Added a Ford ECZ 9425-B single 4 barrel intake, a Holley 390 CFM 4 Barrel, a Pertronix Ignitor III & Flame Thrower III coil. Still gotta work on the tune and add headers.
Old 08-12-2014, 05:39 PM
Rimrock F1's Avatar
Rimrock F1
I am very happy with the C4. I have 3.22 gears and a mildly hopped up 312. Good power off the line and about 2700 rpm at 75 mph. I don't do that much freeway driving so overdrive was not a big concern. The C4 was cheaper and consumes less power to operate that most of the other trans options.
old uhaul
Ford Truck Parts for Sale
10-17-2011 09:15 AM
jmadsen
09-13-2008 12:24 AM
55rodder
13
12-11-2003 07:07 PM
hpguy
02-04-2002 11:29 AM
darkknight
05-05-2001 12:17 PM
Quick Reply: Y block adapted to newer upgrade trans
