Is there anything to give me a REAL DEF gauge?
This is maddening that they warn you they will cripple your engine if you run out of def and the only indication is an electronic nanny ?!?
Mine has said less than half.... for a couple of months and so started getting paranoid that I would be towing === cuz ZERO is less than half ?!?!
am I going to be shut down any mile now ????
I know, I know, other warnings come later, but is there any thing Ford can do to give us a gauge or is there an aftermarket like using a scanguage or torque pro, or ??? to get a better idea ?
So I made a trip over to the flying J to fill up and it only took 2.5 gallons !!!
GGGGRRRRR !!! between the stoopid gooberment making this mandatory with fake science and ford not putting a real gauge on it --- just GGGGRRRR
I can think of a way to make your DEF worries go away.
Any OBD gauge is only able to read the OEM gauge or in this case the lack of one. My Edge CTS is still telling me 66% and I am currently at 430 miles to empty. Like others have indicated, the factory sensors for this just plain suck. I gotta say though worrying about the DEF level prior to 800 miles to empty is just being paranoid. In 64,000 miles my truck has never failed to give me the 800 miles to empty message. Surely you are able to find DEF within 800 miles. Every truck stop in the country has DEF as well as most auto parts stores and even most Walmart stores. I say worry less and drive more!
The RAM DEF gauge is run by an algorithm with the same sensors as we have. Its a dummy gauge.
I don't see the problem. The MTE is like a 500 mile warning....I would think you can find DEF within 500 miles pretty much anywhere in the country.
It can also be checked. I can see the anxiety of the warning, but I would much rather have an EGT gauge than waste the space on my cluster for a DEF gauge that is a dummy gauge.
