Replacing syncros in zf5 has anyone attempted this worth it or not
About 10 months ago a had to do a zf5 swap because my e4od was toast 180000 miles of being a farm truck and tractor hauler then turned over to me it was toast well because of lack of funds and not wanting to put a non built e4od in it I went with the swap now funds were realy tight so I bought a used zf5 from Ian at Ian's truck shop I fought he said it came out of his personal truck he said 3 rd gear syncro was going but turns out it was 2nd but now I'm wandering if I can save some more cash and replace the syncros myself
Replacing any of the syncros require the trans to be totally disassembled, so you may as well go ahead and do a full rebuild on it while you have it out and apart.
Is there any kits out there I'm currently going to a technical school on mechanics so tools to work on it shouldn't be a problem
Depending on which tranny you have: http://www.ebay.com/itm/Ford-ZF-Truc...r#ht_796wt_662 or
http://www.ebay.com/itm/Ford-ZF-Truck-5sp-Transmission-Rebuild-Kit-1987-95-S542-/170594764591?pt=Motors_Car_Truck_Parts_Accessories&hash=item27b83d872f&vxp=mtr#ht_859wt_662
I just bring my trans' to my trans guy. He bench rebuilds them for $450. SO it is not even worth my time to open one up
Subscribing...
...and Brad - you're somewhat close to me in PA here, mind sharing your trans guy? I have an extra trans that needs rebuilding. I wasn't planning it now but for that price I may just go ahead and do it now while I'm tearing everything else apart.
My trans guy is in jersey About a hour ride from me.
Originally Posted by 7.3 forever
Do you guys know of what helps worn syncros perform a little better in these transmissions
so i guess that's a no? :-)
I grew up in Jersey, now live about 30 mins from there and all my family still lives there - so i get there alot. PM me a name if you don't mind. no big deal if you do.
New would be grate but I'm currently saving to do that soon but I'm just seeing if there's something you guys recommend to help while I'm saving to do that I've heard friction modifier help in these zf5 does anyone know if there's any truth to this
