Signs of a loose injector??
#31
#32
I so get that fifty-cent fail mod.
Congratulations! I'm glad you found what you did and it was that easy to resolve. You wouldn't think something that insignificant can change the way these trucks sound - but it does. I've had them as much as a full turn loose - excluding the time #8 prairie-dogged out of the hole and I blew a cup from combustion pressures shock.
#33
#34
Gonna get back into local trucking,
The two tabs were completely broke off
#35
I may have just discovered why I keep losing #7 injector (it gets real loud and I swap it out). My passenger-side fuel line is pinched, right next to the up pipe. I have no freaking clue how that could happen. I've been eying the passenger-side EGT gauge since I installed it, and it was sometimes good, sometimes bad... but never really synced with the driver side. I suspected fuel or oil issues for a long time, but this caught me completely by surprise.
#36
This is the area I'm thing of.
#37
#39
#40
Gonna take my time and squeeze out as much mpg's as possible.
I've spent the last two weekends changing every fluid on my truck, & checking everything. This weekend I'm pulling/inspecting/repacking wheel bearings on the camper.
I'll pick up a spare bearing set just to be safe.
I'm done with Florida...
#42
Thanks Rob. I'm hoping for a non eventful trip.
Rich I have no problem with driving in the snow in my 2wd DRW. Or should I say I have no issue up to about 12" inch of snow with it being a 2wd. Actually being a DRW that helps grab the snow better than a srw. It is lika..like a 4wd just that all 4 drive tires are on the back. LOL I would have made another joke I just don't want to having someone getting mad at me. I think having the B.F. Goodrick Commerical T/A Tractions on the DRW helps alot. My last truck was a '89 F150 4x4 Lariat and I needed the 4x4 when we only had about 6" of snow. Now I would not feel safe driving any 2wd on some of the mountain roads you drive in the winter. I repect you guys that drive in the mountains in the winter with snow and the scarest for me is ice! But with ice it doesn't matter if it is 4wd you are lucky if you can keep it between the lines.
#43
#44
Or should I say I have no issue up to about 12" inch of snow with it being a 2wd. Actually being a DRW that helps grab the snow better than a srw. It is lika..like a 4wd just that all 4 drive tires are on the back.... ...Now I would not feel safe driving any 2wd on some of the mountain roads you drive in the winter. I repect you guys that drive in the mountains in the winter with snow and the scarest for me is ice! But with ice it doesn't matter if it is 4wd you are lucky if you can keep it between the lines.
Depending on the part of Oregon, it could be the "slimy" snow or the fluffy stuff. Slimy snow is what Seattle gets, with those crazy-steep streets. I wouldn't drive the slimy stuff in Seattle with anything but a tank. All those drivers that don't know how to drive on snow - and it's the worst snow on the worst roads in the worst traffic conditions. This is when YouTube loads up with "Amazing Crashes" videos. Anybody remember the city bus almost falling onto I-5? What good does it do to have a practiced driver with 4WD and good tires in a Superduty - when a freaking bus falls on your ***?
#45
