FTE Brotherhood strikes again...Thanks strokin'_tatsch and Toreador_Diesel!!!
Your knowledge of these things is light years above mine, so don't think I'm arguing with you. My thoughts are that I must have an intercooler and I need this truck to be reliable. I also want it to be easily fixable anywhere in the country I might be with it. For the price difference between OBS and Sd up pipes I could mostly switch over to the SD system. My goal at this time is to go with E-pump, SD turbo/up pipes/IC/pedestal, Stage 1s or 2s, 17 HPOP and a tune. I have a WWII in my SD and plan on getting another one if I go the SD turbo on this truck.
Why does the exhaust manifold need to be switched?
I looked dang hard to spot any differences when converting the motor for TXtinct...
Any i found seemed to be cosmetic. Mounting location alignment on all fronts looked identical... but i did not take them to the shop and put them on my bench. It was just eyeball measurements... highly technical lol.
Do you know offhand what the significant differences are Travis?
I still have that set i pulled off the obs motor that went into TXtinct. I had blasted and phosphate treated them in anticipation of putting them on my truck...
I will hold on to them till Zombieheart goes in, and if they dont get used i will offer them up to the Brotherhood for proper disposal. I might revisit the discussion of their differences when i yank the set off Motorbug's ticker.
Aune163rd
04-15-2012 07:19 PM
LSAtexan4x4
11-25-2011 05:39 AM
