1997 f350 crew cab 4x4 diesel fuel tanks capacity
Old 08-03-2014, 09:42 PM
sand1's Avatar
sand1
sand1 is offline
How many gallons is the front and back tank?
Old 08-03-2014, 09:56 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
19 front, 18.5 back.
Old 08-04-2014, 12:05 AM
HOOTs95PSD's Avatar
HOOTs95PSD
HOOTs95PSD is offline
Do we have options for a bigger rear tank?
Old 08-04-2014, 12:32 AM
FI460's Avatar
FI460
FI460 is offline
Home
Bronco tank. Have to lose your spare.
Old 08-04-2014, 01:12 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
There is also a 38 gallon for 87 pickups. http://www.amazon.com/gp/aw/d/B000C7...&robot_redir=1
Old 08-04-2014, 02:49 AM
HOOTs95PSD's Avatar
HOOTs95PSD
Thanks for the links.. I saved them both. When I can get some down time on this truck it will be getting a bigger tank.
Would a fuel sender unit from the 88 truck hook right up to a 95's harness?
Old 08-04-2014, 07:40 AM
Awitte58's Avatar
Awitte58
Awitte58 is offline
If you buy the 38 gallon bronco tank like shown in the first link above you can re-use your factory pickup/sending unit. You just have to modify it to be longer (the tank comes with the necessary hardware to extend it) and make some new slots for the tabs to hold it straight.
I did the 38 rear tank and now I can hold 60 gallons under the truck!
Old 08-04-2014, 07:42 AM
oldbird1965
I tried what I believe was a 80's sending unit and ended up running out of fuel with a half tank. I ended up doing what is written in the 'home' link above.
Old 08-04-2014, 08:39 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel
OldWoodsDiesel is offline
i plan on doing this mod myself when rebuilding my truck.
Jim's write-up is quite clean, but is there really a need to extend the return line? i always like to dispense with extra work where possible :-)
Old 08-04-2014, 09:30 AM
MOOSE_MACHINE
Originally Posted by OldWoodsDiesel
i plan on doing this mod myself when rebuilding my truck. Jim's write-up is quite clean, but is there really a need to extend the return line? i always like to dispense with extra work where possible :-)
I think you would get some air bubbles forming while the fuel drops I to the last half of the tank. Also you may get siphon issues if the return is left out of fuel
Old 08-04-2014, 11:58 AM
OldWoodsDiesel
i woudlnt be concerned with bubbles considering how the fuel sloshes around in there driving. back siphon is a good point, though!
Old 08-04-2014, 12:30 PM
oldbird1965
The hardest part of modding the sending unit is the insertion of the extended rod thru the plastic part is keeping everything lined up. My original sending unit was falling apart and when I tried it, it fell apart. Believe you me, a new one is not cheap and I sweated getting the rod thru.
Old 08-05-2014, 03:43 PM
DarkStarMedia's Avatar
DarkStarMedia
DarkStarMedia is offline
Originally Posted by FI460
Home
My spare has been fine.....
Richard
Old 08-05-2014, 04:40 PM
FI460's Avatar
FI460
FI460 is offline
Richard
Huh. Just repeating what I've read here.
Old 08-05-2014, 04:48 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
It can still be mounted, just lower than stock
Quick Reply: 1997 f350 crew cab 4x4 diesel fuel tanks capacity
