early 99 powerstroke p1670 code. what to do now?
Old 08-03-2014, 12:24 PM
fordguy2236's Avatar
fordguy2236
fordguy2236 is offline
Should I check the battery cables voltage with the key on or off? My cables look clean but I guess it's still a possibility
  #32
Old 08-03-2014, 12:35 PM
fordguy2236
Should I check the battery voltage with the key on or off?
  #33
Old 08-03-2014, 12:51 PM
greg_8507's Avatar
greg_8507
greg_8507 is offline
Key off. There's 12 volts running to the starter at all times. When you turn the key to crank, ground is provided to the starter relay(which also has 12 volts at all times), which then powers the starter solenoid, which provides ground to the starter.
With the key off you should have 12 volts on one of the large lugs and one of the small lugs on the starter relay(with out looking at it I can't say which is the power in terminal). With the key turned to crank, you should read 12 volts across both large lugs as those are the contacts. On the smaller lugs you should read 12 volts on one, and less on the other. That's coil that makes the contacts between the large lugs close.
Sorry if this is a little confusing. I'v never been good at breaking things down.
  #34
Old 08-03-2014, 02:20 PM
fordguy2236
I jumped the two big lugs and all I hear is a clunking from the starter. So bad starter?
  #35
Old 08-03-2014, 02:32 PM
greg_8507's Avatar
greg_8507
A good starter isn't cheap. So you want to remove all other possibilities. Prior to the failure, did it seem as though the starter got a little weaker with each start? I've also seen batteries that will measure 12 volts with a multimeter, but not turn a starter over. Have you had the batteries tested or tired to jump it?
  #36
Old 08-03-2014, 05:04 PM
fordguy2236
Never had batteries tested. Just had starter tested and it's good guy there said could b ignition switch so I just bought one while I was at the parts store. $20 so not to bad. When I jumped the solenoid I forgot to turn the key to one so I'm going to try that when I get home an see what that gets me.
  #37
Old 08-04-2014, 05:15 PM
fordguy2236
Figured it out. New starter and she's back and running
  #38
Old 08-04-2014, 06:24 PM
greg_8507's Avatar
greg_8507
glad to hear it
  #39
Old 10-14-2023, 01:04 AM
Freddy Sanchez's Avatar
Freddy Sanchez
Freddy Sanchez is offline
1st Gear
I have the same code but my truck will crank but no start 😔
Mickey Bitsko
1997 - 2003 F150
04-21-2019 02:29 PM
Super Econoline
03-31-2013 10:49 PM
6pacmac
1999 to 2016 Super Duty
06-20-2011 07:32 AM
wadecamp
03-24-2008 11:04 AM
Quick Reply: early 99 powerstroke p1670 code. what to do now?
