VA August End of Summer BS Thread.
#856
was but i put the O-ring on from the plug and it stopped that... the adapters was too small and let it leak.. put the other o-ring on it stopped it...
apparently thats supposed to be a normal reading...and was getting it for a bit... but after i stopped at a store i started getting this as a constant reading...
stayed there the whole way home... not sure if the sensors bad, the wire harness shorted... dont think its the gauge... unsure of the fuel pump...
#860
#861
yup got the blue spring... was one of the first mods i did...
only one O-ring for the fitting... and had to use the adapter... threads werent the same.. Sensors threads are fine... where the plugs coarse threads..
Did have to use the original oring from the plug... the one that came on the adapter was too small... as soon as the pressure built it leaked..
#864
#870
