Virginia Chapter Join Chapter, Leader:
VA August End of Summer BS Thread.
  #856
Old 08-23-2014, 09:05 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
was but i put the O-ring on from the plug and it stopped that... the adapters was too small and let it leak.. put the other o-ring on it stopped it...
apparently thats supposed to be a normal reading...and was getting it for a bit... but after i stopped at a store i started getting this as a constant reading...
stayed there the whole way home... not sure if the sensors bad, the wire harness shorted... dont think its the gauge... unsure of the fuel pump...
  #857
Old 08-23-2014, 09:51 PM
archtaan's Avatar
archtaan
archtaan is offline
Fuel pressure usually moves, especially under wot. Might be the fitting.
  #858
Old 08-23-2014, 09:58 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
but shouldnt be dropping below 45psi...
  #859
Old 08-23-2014, 10:15 PM
archtaan's Avatar
archtaan
archtaan is offline
Do you have the blue spring upgrade?
,and yes. 45psi is the minimum. I wonder if its an install/fitting issue. Maybe one of those o-rings gave out?
  #860
Old 08-23-2014, 10:18 PM
fire240's Avatar
fire240
fire240 is offline
Have a good one guys. Almost time for me to head out for the night.
  #861
Old 08-23-2014, 10:26 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
yup got the blue spring... was one of the first mods i did...
only one O-ring for the fitting... and had to use the adapter... threads werent the same.. Sensors threads are fine... where the plugs coarse threads..
Did have to use the original oring from the plug... the one that came on the adapter was too small... as soon as the pressure built it leaked..
  #862
Old 08-23-2014, 11:56 PM
archtaan's Avatar
archtaan
archtaan is offline
Looks like you will need to call and see if they can send you the correct fitting. I think its not ready right because its probably bleeding pressure.
  #863
Old 08-23-2014, 11:59 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
im wondering if i broke the wire pulling it through the fire wall
  #864
Old 08-24-2014, 12:17 AM
archtaan's Avatar
archtaan
archtaan is offline
If you have a voltage tester you can check it before and after to see if there is voltage drop. Its possible its ground shorting though.
You could run a new wire outside the cab into the gauge just to check it. That way you dont have to deal with fishing it through the firewall.
  #865
Old 08-24-2014, 12:20 AM
Sparky83's Avatar
Sparky83
Sparky83 is offline
when the ground itself is bad the needle pegs to 100... had that already.. ground wire backed out when i plugged into the gauge..
  #866
Old 08-24-2014, 12:21 AM
Sparky83's Avatar
Sparky83
Sparky83 is offline
was reading online earlier.. that apparently alot of people have gotten bad sensors from them..
  #867
Old 08-24-2014, 12:35 AM
archtaan's Avatar
archtaan
archtaan is offline
Do a quick wire test then call them. They will take care of it. I'm off to bed. Later.
  #868
Old 08-24-2014, 12:41 AM
Sparky83's Avatar
Sparky83
Sparky83 is offline
i emailed them asking for how to test the sensor..
  #869
Old 08-24-2014, 10:55 AM
archtaan's Avatar
archtaan
archtaan is offline
Probably measure the ohms
  #870
Old 08-24-2014, 11:10 AM
GLR's Avatar
GLR
GLR is online now
Good "Go Topless Day" to all.
Quick Reply: VA August End of Summer BS Thread.
