Fuel filler tube flex hose?
After my accident in July I had a new hitch put on the Ex. After 4 fill ups I started having a fuel leak when the tank was all the way full.
I am assuming that means the hose from the filler neck to the tank is cracked.
The two questions I have is do I have to get the hose through Ford or can I get bulk hose at NAPA for replacements?
Might be a problem using bulk hose if there's a sizable bend. I haven't looked at mine, so I don't know. In case you decide on the Ford hose....
Fuel Filler Hose for 2003 Ford Excursion|YC3Z-9047-AA
I don't remember what your accident involved so I was guessing it was rear end if you had a new hitch put on. Ask the hitch installer if they moved the tank as it's very possible they didn't get the tank or one of the vent hoses back on correctly. The hoses are pretty durable but easy to not get connected properly.
Brown Falcon
01-01-2009 02:29 PM
cpt97M3
43
05-06-2005 09:13 PM
