Torque specs 1999 E350 rear axle
Old 07-31-2014, 12:51 AM
CopperBurst's Avatar
CopperBurst
CopperBurst is offline
I'm in the process of replacing rear rotors on a 1999 E350 Xlt 5.4 V8. Upon removing the rear passenger rotor the parking brake was covered in grease. So I replaced bearings and seal on that side. I'm trying to find the torque specs for the spindle nut, caliper bracket bolts and the caliper bolts. I don't know if it helps any, but the axle code on the door sticker is 39. Thanks!
Old 07-31-2014, 07:13 AM
jimandnena's Avatar
jimandnena
jimandnena is offline
Hi Copper,
I don't know if this helps either but I found a service book for a Dana axle which may or may not be of any help. The book lists the ID axle tags if that helps.
http://www2.dana.com/pdf/AXSM-8941.pdf
Good luck!
jim
stbernard
1999 to 2016 Super Duty
09-15-2015 11:00 AM
tgcapizzi
03-12-2013 07:18 PM
dfink12345
10-19-2011 06:51 PM
chip99
05-12-2010 12:22 AM
mjb196
06-13-2009 06:08 AM
Quick Reply: Torque specs 1999 E350 rear axle
