Need a remanufactured 7.3 Long Block
I heard one guy ask a similar questions about my 6.7 that runs at 25k psi, completely different systems. It's not a dumb question if you don't know or understand what's going on within it. You could hurt yourself/someone bad enough to not feel the pain if you get what I'm saying
I do that every time I pull and install an injector, one head at a time. With the 42 pin connector off, I pull the ICP sensor from the left head and crank until I get a little oil out of the port, then replace the ICP sensor and pull the furthest forward rail plug I can get to easily and do the same thing. I also bleed the air out of the fuel rails by loosening, but not completely removing, the test port plugs one at a time and turning the key on until some fuel seeps out from the threads. It probably doesn't need to be said, but don't do either of these things with an injector out . . .
Before giving up hope on the engine, aerated oil makes gawd-awful banging - not unlike a rod knock. Remember the upper half of the engine is fed oil from the injector oil spouts, not from lifters and pushrods like on conventional motors. When the oil gets too low to feed the HPOP, the engine just stops, but the air in the oil will make it run rough and knock before dying. I've heard that sound more times than I can count - remember I'm the 'jector popping king. Have another shop replace the oil (on the first shop's dime) and see what happens.
Guys I hear ya load and clear here
And yes I thought about it when the boys woke me up to tell me about the truck.
I noticed the truck was running a little rough / off par the last 2 miles as I was pulling up home. I was too tired to look into it at that moment and just parked it.
I'm thinking the truck was running off the bottom of the pan, sucking some air, pulling a 10K trailer on a 104F July afternoon, through no fault of my own due to the shoddy workmanship from a Corporation that pushes these young mechanics to cut every conceivable corner to rake in a profit and still doesn't pay these kids a livable wage
Your Damm Straight an oil sample is being pulled and tested by an independent lab
The symptoms of the rod knock are also right in line with scorched / scarred crank bearings starved for oil on a hot day that cooled off and were restarted again.
The oil analysis will tell the tale
Guys - I'll keep you posted
Because there is a "claims adjuster" representing the national chain store Ford Fleet Service will not be inspecting the engine until next week. At that time once an oil sample is taken, they will refill the engine with oil and finish diagnosing the truck's engine.
#28
Ford Fleet Service gave my truck a "Clean Bill of Health"
Said there was NO metallic substance in the oil sample. The cause of the leak has been attributed to a Failed Oil Filter Gasket (ya right) and Ford Fleet changed the filter and oil.
Of course I set my Banks 6 Gun up to Warp 6 and 'punched it' all the way home just to make sure
#30
So all is good in 7.3 land again? Good to hear if yes!
