Air conditioning woes.
Ok, can you elaborate? If you only block the flow at one side of the heater core, how does the water get back to the block/pump? The video I saw uses the 74809 valve from Autozone, which shuts off the flow to the heater core and routes the coolant back to the block/pump. Does it simply just need to have the flow blocked at the core and not need to circulate?
The heater core is not apart of the necessary route of coolant for the engine, just an accessory pathway, from the block, to the heater core, and back to the system through the water pump. Cutting off one hose, simply stops the flow to the core and will accomplish the same thing as the two hose. I just prefer the dual hose valve for science reasons that I could make up if I had any facts behind them
Thanks for plugging my video guys!
I think both part numbers I gave you were for four hose connections to redirect the water back. I know the Ford one is for sure, that's the one I bought. Payton has a good how to install with pictures, look it up, very easy. He also tells you what vacuum line to tie-into for what you want.
Okay Folks Air conditioning is much colder, Thanks for all the suggestions. I changed the Fan, relay and blend door actuator plus added the valve to stop the water going into heater core, but I still dont think I am getting enough velocity from the fan passing through vents. If I shut one vent then of course it improves. Any other suggestions?
Is there a different fan motor that would be better? or fan blade change to force more air?
Note: According to my Hanes manual (FWIW) Place a thermometer in the center vent, place fan on max, have a/c on but not on max. Rev engine to 1200 RPMs and hold. If you are seeing 30* below ambient or better a/c side of things is working great. < 30* ambient you have an a/c issue. On a 90* day I am getting 50* out of the vent, going down the road it gets a little cooler upper 40's.
Definitely will be looking into installing the valve. Our truck has and odd habit, when cruising down the road with A/C on normal or Max it is cool but not super cold, but if you slow down like pulling into our neighborhood it gets real cold fast. All I can contribute it to would be less flow of coolant through the heater core when idling down. Thanks for the above info. Matt
#28
