1994 f150 lift
Hi there.
With 2-2.5 inches of lift you should be able to clear those 33's. I know I could on my old truck, but they were only 9.50 wide.
For 2.5 inches of lift, you'll probably be wanting to look into a leveling kit. There is mixed controversy about them, but personally I had one on my old 93 f150 which was a hard worker and wood hauler and never encountered a single issue with it. Most of these kits come with a 2.5" coil spacer for the front, and either 2.5" blocks to go under the leaf springs or add-a-leafs. Typically they'll run you no more than $100 depending on where you get it. Summit racing and eBay carry them to name a couple. I got mine on ebay for 80 bucks and I never had a problem with it. Just make sure the blocks for the rear that go under the leaf springs are tapered or 'slanted', and made of a reliable material such as cast iron. You also might need longer ubolts after you put the block under the leaf pack, but most kits come with those. As for the front coil spacers, make sure they're something like billet aluminum and not polyurethane or plastic. Just for the sake of avoiding disaster.
You'll probably hear a 'bad thing' or two about leveling kits but if you're not looking to spend hundreds of dollars for 2.5" of lift then a leveling kit is the way to go. Like I said, I ran one for three years on my previous truck before I sold it and had no problems.
Good luck
Good luck
Sure, here's the link. This isnt the exact same one I had but it's almost identical. If you search something like "94 f150 lift kit" or "94 f150 leveling kit" stuff like this should come up. You should try to find one with cast iron blocks and aluminum coil spacers. Make sure it comes with shock extenders and u bolts. I believe the example link I posted has polyurethane spacers, but you get the idea. Good luck man
http://www.ebay.com/itm/SOLID-LIFT-KIT-FRONT-2-REAR-2-BLOCK-U-BOLT-W-SHOCK-EXTENDER-4X4-4WD-/261311364395?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1995%7CModel%3AF-150&hash=item3cd75efd2b&vxp=mtr
I agree with Evan, obviously bigger tires will decrease acceleration, and the more weight you're pulling would only make it worse. But considering you already bought them, you might as well put them on. Or perhaps have a set of rims with stock tires and swap em out when you know you're gonna be carrying a **** ton of weight.
New F250 coils (Moog CC844) are only ~$65 on Amazon. Then buy some adjustable camber bushings, set them up to add ~1.5* of camber in addition to whatever bushings are already in your truck (mine had 0.5* on one side and 0.75* on the other factory bushings). If you want to level the truck, you don't want to lift the rear, but I think "leveled" trucks for hauling are a **** poor idea. You want a 2" rake so it's level when loaded.
As others have said, don't put big tires a pulling rig unless you want to regear.
That's what I did with my 1970 F100 4X4. I put coils in from a Super Cab. Lifted the front of my F100 a couple of inches and the ride wasn't too bad. If I remember right it was simply firmer but not harsh.
