Front + Rear Shocks Recommendation / Replacement
Old 07-27-2014, 09:57 AM
Augy88066's Avatar
Augy88066
Augy88066 is offline
Hello all,
I am looking to replace all four shocks on my lifted 1979 Ford Ranger XLT Supercab + Longbed with new shocks. My riding style is 80% road and 20% dirt.
Can you provide me with good shock recommendations? It has been 10+ years since they have been replaced.
Thanks!
Old 07-27-2014, 10:11 AM
Blue and White's Avatar
Blue and White
Blue and White is offline
I am running Gabrial "premium" gas shocks on my '78 F250 4wd. It is stock height and near stock size rubber. They work fine in my application and are not too expensive.
Old 07-27-2014, 04:16 PM
jp1251's Avatar
jp1251
jp1251 is offline
shocks as well
I've got a '78 ford f250, 300, 2WD.
I'm replacing the shocks as well, so if anyone has advice on performance shocks I'd like to know what you think (brand, website, etc).
Old 07-27-2014, 06:42 PM
AK FORD GUY's Avatar
AK FORD GUY
AK FORD GUY is offline
I have run KYB's on my last three trucks, I have been satisfied with them so far.
The only ones I put a lot of miles on, were in a 1997 F350 Crew Cab Diesel and they did fine.
Old 07-27-2014, 08:01 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
These rigs ride rough due to stiff springs and coils. It really doesn't mar what shock ya put on them. Let your budget be your guide.
The most common are Monroe Gas Magnums, KYB GR-2s, and Rancho 5000s. On the upper end are Bilstein shocks.
Regardless, visit Bilstein - KYB - Rancho - Monroe - Edelbrock Automotive Truck Shocks and Struts - Shockwarehouse.com for good prices and fast delivery. Their customer service is also above par.
Old 07-27-2014, 08:58 PM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
shocks
I ran bilstiens on my old deisel,I really like them.Hio hooked me up with shockwarehouse,and they pulled numbers and sent me the correct rear shocks.For the fronts to use bilstien I have to adapt this part.
Pro Comp Shock Mount Conversion Kits 690002
Summit
Image is a representation of this item.
Old 07-27-2014, 10:20 PM
fordrealdrive's Avatar
fordrealdrive
fordrealdrive is offline
Originally Posted by Augy88066
Hello all,
Thanks!
Hi, if you know the lift manufacturer and the amount of lift, Then replacement shocks should be readily available. Also most companies have at least 2-3 levels of quality/performance/price too.
Summit
Hey lafermedavid, have you mounted your front shocks yet, and if so, how well do those adapters work with the factory mounts? Thanks
Old 07-27-2014, 11:17 PM
OldMetal's Avatar
OldMetal
OldMetal is offline
Same here, I used to work for a major Ambulance company and KYB's was all we used
Old 07-28-2014, 06:59 PM
jp1251's Avatar
jp1251
jp1251 is offline
Thanks for the info HIO Silver.
Old 07-28-2014, 07:07 PM
oddfordjunkie's Avatar
oddfordjunkie
oddfordjunkie is offline
I've got Bilstien 7100 remote reservoir shocks in the front and Rancho RS9000 in the rear, when I find another set of Remotes for a deal I'll put them on the rear.
I had Monroe gas charged shocks all the way around before and I will never put bargain or OEM type shocks on a vehicle again after running the Bilstiens.
Old 07-28-2014, 07:12 PM
HIO Silver's Avatar
HIO Silver
'Glad to help.
Old 07-28-2014, 09:19 PM
lafermedavid
shocks
''Hey lafermedavid, have you mounted your front shocks yet, and if so, how well do those adapters work with the factory mounts? Not yet Chris,till motor installed.I have not even purchased the fronts.I cant see why that shock bracket would not work,sorta like something you would fab.Would allow me to run the 5100 in the front ,like the rear.Unless the resevoir is a major improvement,which I do not know.
Old 07-28-2014, 09:26 PM
highoctane74's Avatar
highoctane74
highoctane74 is offline
I'm running the Bilsteins on my truck, been great so far. Rancho's didn't last long on my other truck.
Old 07-28-2014, 09:39 PM
oddfordjunkie
Reservoirs on shocks is mainly to add fluid capacity and reduce shock temperatures, not needed on a street vehicle. For the type of uses I'm building my truck for (prerunning) it's a benefit.
Bilstien sells shocks with a Stud type top mount, so you wouldn't need the adapter.
Personally I'm poor so I use the best parts I can get a deal on, those adapters wouldn't be hard to make at all.
Old 07-28-2014, 09:58 PM
HIO Silver's Avatar
HIO Silver
It's clear that you haven't seen some of the roads in the mid-West nor county-maintained roads in Khalifornia.
Quick Reply: Front + Rear Shocks Recommendation / Replacement
