1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
new shocks for both trucks motorcraft,kyb,bilstein,other?
Old 07-21-2014, 09:01 PM
F-WhiteThunder's Avatar
F-WhiteThunder
F-WhiteThunder is offline
2000 f450 superduty v10 dual dump 2wd
2004 f550 superday 6.0l dual dump 2wd
are motorcraft monotube? if not should I swtich a monotube to the kyb monomax or the bilstein??
Old 07-21-2014, 09:17 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
mono tube is a whole new league of performance...if you can spring the coin...go for it.
Old 07-22-2014, 07:49 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Oops, started to add to the which shocks are best debate before it got started
but sorry, no experience for dump trucks !
rancho 9000 adjustables for all other superduties
Old 07-22-2014, 11:34 AM
AAubinoe's Avatar
AAubinoe
AAubinoe is offline
I just got a set of yellow Monroe Gas Magnums for my truck, its just a 3/4 ton though. They are much bigger then the ones I put on my sisters XJ Jeep Cherokee and my Jeep Grand Wagoneer, so I imagine they would be even more so for your application. My favorite budget shock by far. Rockauto has good prices on them.
Oh course a bilstein would be better, but you can get 4 monroes for the cost of 1 of those!
Old 07-22-2014, 01:57 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Lubbockguy1979 is offline
Been happy with bilstiens on my truck. Dony have any issues with aftermarket ranchos but ford ranchos are junk in the fx4 package
Old 07-22-2014, 07:42 PM
F-WhiteThunder
I just was able to get part numbers off the shocks on the 2000 f450 superduty v10
front motorcraft F81a-18045-bna under it is cl30s1d
Rear motorcraft F81a-18080-dca under it is cl29s1s
these numbers are from 2000 original shocks they probably have superseded numbers does anyone know ?
im looking on rock auto but no matching numbers that's because a new number probably took its place.
so im gonna with motorcrafts , kyb monomax or bilsteins but need to figure out what f47 model is for the kyb brand
Old 07-25-2014, 09:27 AM
F-WhiteThunder
deciding on the kyb monomax and bilstein for the 2000
Old 07-25-2014, 12:13 PM
gasman6674's Avatar
gasman6674
gasman6674 is offline
For what its worth I put a set of KYB's on a 94 E350 motorhome I use to own and was extremely happy with them.
Old 07-25-2014, 12:21 PM
F-WhiteThunder
tough call but might be leaning towards bilsteins for the lifetime warranty and made in the usa / European family / etc
Old 07-25-2014, 01:46 PM
dkf's Avatar
dkf
dkf is offline
The Bilstein lifetime warrenty looks like a joke to me. A guy here on FTE had 2 of his front Bilsteins blow on his super duty with a slide in camper and Bilstein said they would not warrenty them. He was running a washboarded dirt road to a state or federal park when they popped. So I won't even bother looking at Bilstein products.
I have been running the Monroe Reflex shocks for a few years now and so has my dad. So far they have been working well. They are starting to rust up pretty good so I guess I'll have to do their shock exchange soon to get new ones.
Old 07-25-2014, 01:49 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
They didn't just "pop", they freaking melted the shock boots. It was crazy. Denied warranty for "offroad use" of shocks specifically designed for lifted applications.
https://www.ford-trucks.com/forums/1...k-failure.html
Old 07-25-2014, 03:57 PM
dkf's Avatar
dkf
dkf is offline
Thanks for posting the thread I did not have it handy. +1 to you.
Yeah Bilstein proved why I don't put much faith in warrenties, they are only as good as the company giving the warrenty. It is obvious in this situation Bilstein is a crappy company. A company that sponsors, makes, markets and etc shocks for offroad use. Though I would say in this case the guy was not "offroading" IMO. He just got on a bumpy road which is very common.
I have never had an issue over the years loaded at or above GVWR on anywhere from bumpy mountain roads, to canadian dirt roads to the big holes in interstates and PA roads without issue.
Old 07-26-2014, 09:44 AM
F-WhiteThunder
bilsteins got for $255 4 shipped
Old 07-28-2014, 02:20 PM
brian42's Avatar
brian42
brian42 is offline
x2
Switched to the Rancho RS9000XL shocks and never looked back. There was a rebate when I bought my set so whichever ones you do buy check for a rebate deal too.
Old 07-28-2014, 02:25 PM
AAubinoe's Avatar
AAubinoe
AAubinoe is offline
Originally Posted by brian42
x2
My fear with those is that they will corrode just like everything else and the valve would seize. How exactly do they work?
They let you turn in your old shocks when they rust?
Quick Reply: new shocks for both trucks motorcraft,kyb,bilstein,other?
