What fuel pump should I get?
Old 07-24-2014, 12:42 PM
jlo84truck's Avatar
jlo84truck
jlo84truck is offline
I have a 2003 f250 6.0 with 155/30 injectors. Just wondering what you guys are doing to keep the fuel pressure up to support these injectors?
Old 07-24-2014, 12:48 PM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I'm running one of the upgraded AD165's with the commercial pump motor. Call the store in Missouri to order one.
Old 07-24-2014, 01:00 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,392 Likes on 2,089 Posts
If anyone knows pumps it is Tim. Do you have a regulated return already?
Sent from my C811 4G using IB AutoGroup
Old 07-24-2014, 07:21 PM
jlo84truck's Avatar
jlo84truck
I thought a lot of people were having problems with the airdog pumps.
Old 07-25-2014, 05:12 AM
npccpartsman
They were, because of unapproved changes by the pure flow folks, but that has supposedly been remedied. My pump has NEVER been this quiet.
Old 07-25-2014, 12:37 PM
jlo84truck's Avatar
jlo84truck
So what do you pay on fuel filter changes? ( airdog filters and maybe upper stock filter)
Old 07-25-2014, 02:15 PM
npccpartsman
The water separator is washable/reusable. The filter is a bit expensive from AD but I never could find a fleetguard that didn't leak. I don't run the upper filter since the AD is a 2 micron.
Old 07-25-2014, 02:48 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
You can get the filters at Napa. Much cheaper and IMO, just as good. No issues except the petcock leaking, easy to change.
Old 07-26-2014, 05:46 AM
npccpartsman
My filters were leaking from the top of the case. Never had as issue with the AD filters even though they're probably made by FG too.
Old 07-26-2014, 07:04 AM
tex25025's Avatar
tex25025
tex25025 is offline
I used a FASS 150/180 on my truck and I also had 155 injectors on it as well. 7yrs and it supported those injectors fine. It was a loud fuel pump, I will say that, but after yrs of blasting my eardrums out, I got used to it soon enough.
I haven't looked to see what the equivalent fuel pump is now for the one that I had (I'm sure they have changed models sense then).
Maxium mentioned an RR kit. I did run one of those as well in conjunction with my fuel pump.
Old 07-27-2014, 12:51 PM
jlo84truck's Avatar
jlo84truck
Has any one done the 6.4 pump install feeding the 6.0 pump? I've been reading up on people that have done it but still kinda confused about the wiring of it.
owenstout
08-21-2010 06:40 PM
Timurgen
03-29-2009 01:30 PM
crazylewi
12-29-2006 03:15 PM
crazylewi
06-15-2006 08:48 PM
Quick Reply: What fuel pump should I get?
