Bolt in Axle Third Member in C Clip Housing?
Old 08-05-2014, 10:50 PM
BMW2's Avatar
BMW2
BMW2 is offline
I picked up a rear end and front third member with 4.88's and a detroit locker in back for a great price but the third member is an earlier style without c-clips. Seems like it would work fine but wanted to make sure there weren't any issues using it. I needed to do the spring trick anyway. Oh, '85 Bronco
Old 08-06-2014, 05:50 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
If it doesn't have the clip, you need to retain the pass side axle somehow. The ones without c-clip had a retainer plate on the passenger side housing with 3 or 4 bolts. Does yours have this and will it hold the axle from coming out?
Old 08-06-2014, 09:56 AM
BMW2's Avatar
BMW2
BMW2 is offline
No, it didn't come with the retainer. I've been having a hard time finding a picture of what it looks like so I can keep an eye out at the JY but I'll probably just run a spring in the slip yoke.
Old 08-06-2014, 12:25 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
It uses a 9" style press on bearing and retainer. The bearing and seal are different than the c-clip axle, as well as the stub axle.
With the right parts no spring is required.
Old 08-06-2014, 12:36 PM
Franklin2's Avatar
Franklin2
The retainer for the older trucks looks sort of like the picture below. The bolts thread into the pumpkin casting.
Old 08-06-2014, 02:14 PM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
Try the BroncoGraveyard for some pictures and parts -
http://broncograveyard.com/images/ad...4ttbxplded.jpg
jwxb41b
04-23-2005 08:05 PM
tm winchester
02-08-2004 02:55 PM
regoruler
01-11-2004 01:07 PM
rebelford
1978 - 1996 Big Bronco
16
06-26-2002 07:49 PM
Quick Reply: Bolt in Axle Third Member in C Clip Housing?
