300 I6 running 175 lbs of compression
Hi! One of my friends has an 83 ford f100 with a 300 6, it seems to run rough, the number 5 hole runs about 75-80 lbs of compression, the others run 175-180, I think it needs a head gasket, but is it normal for this engine to run so much compression? It's a stick engine, never rebuilt. Thanks in advance
175 does seem a bit high. Generally, a good, healthy engine is around 150 - 160. I've heard of compression going up from carbon buildup inside the cylinders.
Definitely pour a little oil down the spark plug hole and try the compression test again. If it's the same, it's either the valves (or possibly the head gasket). If it goes way up, you know the rings are bad and it's going to need some work.
gregorian
26
03-26-2018 12:53 PM
truck crazy man
17
02-06-2014 07:50 PM
nstueve
09-15-2010 04:23 PM
TheNomad
06-18-2008 08:35 PM
