Stalling and hard start 1987 F250 6.9L
Old 07-23-2014, 02:54 PM
RBerry9511's Avatar
RBerry9511
RBerry9511 is offline
Exclamation Stalling and hard start 1987 F250 6.9L
I just got my truck back from the mechanic it ran fine for a couple of days but now it will stall on short trips and is hard to get started again. I can get it started but takes a lot of cranking. It will run ok for a little while but stalls again if I let off the fuel. I did hear a sound that sounded like a large amount of air when I was trying to crank it by jumping the relay for the started. Is this normal? Is it the fuel pump or could it be air intrusion? Please help......Thanks. And yes I will be calling the mechanic.
Old 07-24-2014, 11:50 AM
irhunter's Avatar
irhunter
irhunter is offline
Why was it in the shop in the first place?
Miles on it?
When it happens again, look in to fuel filter...is it dry?
Roy
Old 07-24-2014, 12:03 PM
David7.3's Avatar
David7.3
David7.3 is offline
Allway's check the fuel supply hose, right were it goes into the pump, ford put that crazy angle on them and it's in a tough spot, they rot out and split then it sucks air and no amount of priming can fix it. Take a long nozzle blow gun and wrap some wet rags around it and blow into the fuel tank and leaks on the supply side will show up with a puddle of diesel, make sure you sponge that up and put it back into the tank, 4 bucks a gallon, I dont waste a drop.
you need just slight pressure 5-6psi have a friend check around the fuel lines and listen, you'll know when you found it, my 86 had 475,000 and when I sold it to my niehbor that was the original pump, did that hose twice but could not kill that pump.
Matt1966
09-03-2017 05:11 PM
LandYacht99
10-07-2012 10:01 PM
Otahyoni
10-08-2011 07:51 PM
dimerol
21
12-14-2010 11:10 PM
1966ford
General Automotive Discussion
01-23-2006 02:07 PM
Quick Reply: Stalling and hard start 1987 F250 6.9L
