warped exhaust manifolds
Old 07-22-2014, 08:49 AM
blick's Avatar
blick
blick is offline
I have an 08 F150 with the 5.4 in it. My exhaust manifold (s) are warping. The exhaust leak isn't that bad yet and it quits once the thing gets warmed up, but it's annoying as heck. Anyone else have the issue? I was going to look at buying headers if I'm going to be buying manifolds anyway. Any suggestions on reasonably priced headers?
Old 07-23-2014, 01:30 PM
GUERILLA's Avatar
GUERILLA
GUERILLA is offline
Mine's in the shop for this right now. It started on a cross country drive pulling a trailer going about 75mph pretty much all day long. They quoted me anywhere from $700 to $1100 depending on how many of the studs break off in the process. I'll let you know how it goes. If you do a search on here its a common problem which really sucks.
Old 07-23-2014, 01:34 PM
blick's Avatar
blick
blick is offline
The stud breakage is the killer. I'm guessing that I'll be doing alot of drilling and tapping in a place that's really tight. I think I'm going to order a set of Cat forward headers from SUmmit Racing or somewhere like that. I found decent ones for about 450 bucks. If I'm going to replace them, I may as well beef her up a little.
Old 07-23-2014, 01:49 PM
sammy77's Avatar
sammy77
sammy77 is offline
My '07 Explorer 4.6 had this problem as well. Cost me $1k to do the passenger side. Two years later the drivers side is acting up. There should have been a recall for this crap! No reason for those things to warp.
Old 07-23-2014, 01:54 PM
GUERILLA's Avatar
GUERILLA
GUERILLA is offline
I know man. I'm just waiting for the drivers side to go bad. The exhaust shop I took it to said they do 1 or 2 a month.
Old 07-23-2014, 02:03 PM
sammy77's Avatar
sammy77
sammy77 is offline
It's a bitch to do them as well..
Old 07-23-2014, 02:17 PM
blick's Avatar
blick
blick is offline
I figure it will take me a few evenings to get them both done. Just waiting for some decent weather so I can ride the motorcycle to work while I have the truck tore apart.
Old 07-23-2014, 02:27 PM
sammy77's Avatar
sammy77
sammy77 is offline
The passenger side alone took the tech 8 hrs.
Old 07-23-2014, 02:29 PM
blick's Avatar
blick
blick is offline
wonderful, eh? Maybe I'll get lucky and most of the studs won't snap off. yeah right.
Old 07-24-2014, 12:59 PM
sammy77's Avatar
sammy77
sammy77 is offline
Keep in mind mine was on an Explorer. There's seems to be more room in a F150 to do the job.
Old 07-24-2014, 04:13 PM
NLPRacing's Avatar
NLPRacing
NLPRacing is offline
My 2007 Expedition has a warped manifold on the passenger side. It started on our trip back in June from Texas to Orlando while I was pulling our travel trailer. I just ordered some Gibson model GP218S-C headers for under $400 delivered. Once they come in, I'll be dropping it off at my mechanic. He told me it'll run about $800 just for labor to install them, maybe more if there's trouble. It was either that or pay $600 or more to replace just the passenger side iron manifold with another iron manifold. Since we'll be keeping it for another 3 or more years, I decided to upgrade.
Old 07-24-2014, 05:02 PM
CaptFX4's Avatar
CaptFX4
CaptFX4 is offline
You might be waiting for awhile. The drivers side doesn't go bad that often. It is more of an issue on the pax side only.
That being said, my pax side ticking drove me nuts so I had it changed and had the drivers side changed at the same time even though it was perfectly fine.
Old 07-25-2014, 02:10 AM
Ranger Bob's Avatar
Ranger Bob
Ranger Bob is offline
the fact that pisses me off is FORD has known of the issue since late 2004 (at least) and waited several years to remedy the problem. Same with cam phasers, spark plugs, etc., etc.. I had to repair mine, $1100. A lot of good info. here and elsewhere on the web.
Old 07-25-2014, 08:27 AM
GUERILLA's Avatar
GUERILLA
GUERILLA is offline
Got mine back from the shop yesterday. $850 Installed. I went with another stock manifold because I didn't want to pay for the labor to replace both of them if I didn't have to. I've put about 3 grand in my 05 FX4 since I got it in October. I hope this is the last of the troubles for a while. NLPRacing I had the same deal. I was driving cross country pulling a trailer when mine went.
Old 08-03-2014, 11:24 AM
NLPRacing's Avatar
NLPRacing
The headers came in, I'm dropping it off on Monday to have them installed. Hopefully I'll get it back in a day or two.
Quick Reply: warped exhaust manifolds
