My 96 bench seat is split at the seams and its getting worse, can I buy a replacement cover from anywhere, so that it matches the rest of the interior ?
Automotive Interiors & Accessories for cars, trucks, vans, & suvs looks like they can furnish a replacement, but it won't be a precise copy of the original. You're going to be in it for a good several hundred bucks all done, and that's with you doing the work. LMC has a kit but it is not exact either, and is pricier. If you are at the point where you need new main foam too, it's probably time to look for an upholsterer, because upholstery has got to be about the most physically demanding part of a restoration.
