99 F150 ABS Light On
Ive been following this as our econoline has exactly the same juddering/abs light on issue. The dealer has told me that we need the two front speed sensors replaced and the "hydraulic modular balancing unit" whatever that is - and I guess at $560 its expensive enuf to have an impressive name!. Ive been in lots of vehicles with ABS lights staying on, anyone know if its possible to switch the whole thing off and avoid the cost?
My mother owns a GM product, and when her abs light came on it was just a burnt out brake light bulb. Not sure if Ford will do that or not, but only takes a second to check that both lights come on when the brake pedal is aplied.
In Ma. they plug into your data port under the dash for inspection sticker. If it shows a problem with abs, or air bag, you flunk. Taking out the abs bulb won't help on 96 and newer obdII.
Hey guys,
I decided to cancel my appt. with the shop and do one last thing myself. I changed out my R.F. ABS sensor last night. I chose this one purely by elimination, as I have just replaced my rear sensor the other day and my L.F sensor is only 3 months old. It came with my new L.F. wheel bearing/hub assy. So I still had the old worn out hub/bearing that came off the left side and it had the ABS sensor still in it. I removed it from that old thing and put it in my right front hub on the truck.
I drove the truck today and it performed flawlessly. But, due to the random nature of this problem I cannot confirm nor deny success of my repair!
I will keep you all updated.
Rick
Rick
Hey Big60.
Did this solve your problem? I have the exact same thing going on.
I was going to replace my rear sensor b/c it is cheap. If that doesn't do it, then I'm going to change my front left b/c my right front hub & bearing just got changed (3 months ago).
I did not keep the old hub. Wish I would've as it seems from your post these sensors are interchangeable.
Was it hard to get your front sensor out? I've heard many people say they broke theirs off in the hub.
Please let me know.
Please let me know.
I too have problems with my 97 F150 with 4 wheel ABS. My light come's on seratically but the only issues I have is that I can smell burning brakes from the rear.So I changed the brake,wheel sylinder and brake drum.Then it started making the burning smell fromm the other side so I changed the wheel cylinder and drum.Still smell burnt brakes.I took the drum off and it was purple from how hot it got! I disconected the emerg brake still drum is hot but not as hot,still a problem so I disconected the ABS wire harness on the diff. No differeance so I hooked it back up.I am going through so much fuel.I have a code reader but it comes up nothing. At $118 per hour I don't want to bring it to a dealer. Maybe rear sensor but I unpluged it,would that not fix my problem if it was a rear sensor? Is there any other Idea's I should try.I did buy a used ABS module but it hasn't arrieved yet.
ABS
I fixed my ABS problem. It was the front left sensor going bad. I replaced the whole hub because it was starting to go bad anyhow (the right one was way bad).
Anyhow, I think these trucks are junk. I know everyone on here is going to backlash me... but I had a 97 F250 that was a good truck. I had a 99 F250 that was a good truck. But the F150s in this group just aren't good trucks.
Are you sure you front brake calipers are not collapsing some? Common problem - especially in these trucks. Check those out b/c it sounds like you have pretty thoroughly checked the rears.
But it's my rear brakes that are giving me the problems. I have no issues with my brake pedal all I have is the brakes in the rear that are coming on and heating up my brake drum and making my fuel economy go down the tubs plus my shifting of my transmission is altered because of this.I can feel that my tuck is lagging
rear window leaks
windshields leak
ABS
spark plug/head design
heater core hose leaks onto the spark plug
power windows don't work right
power locks don't work right
transmissions fail....
Could your rear brakes be adjusted out too far? I usually do about 1-1/2 spins by hand on my rear tires. When I get there, I know I'm adjusted about right (usually).
There are several methods to get you adjusted "properly." But, for now, I'd adjust them down and see if the brake-drag is still there.
I'm surprised you don't have disc brakes on the rear...
Yes, my rear window leaks, ABS sucks, my heads have problems (and I have an oil leak involving my right head right now), I've had to replace the power mirror switch but nothing on the locks/windows, transmission has always been "clunky", rear diff problems, brake/cruise switch JUNK, tie-rod ends JUNK, brake rotors are cheap.
And this truck has been well-maintained... I can't wait to get rid of it.
#29
#30
1998 ford Expedition
Hello all I have been reading this thread to try and solve my brake issue, I have a 98 for expedition 200200K 2 wheel drive 4 wheel disk brakes, And here is my issue, When turning right only at slow speeds the brake pedal will pulsate and create a near no brake condition, after it happens a few times the ABS light comes on, after the light comes on the pulsation goes away, It only happens right, New rotors, bearings pads, brake hoses, Any ideas?
