1987 300 shuts down -no restart 4-5 miles into trip
Received 3,118 Likes
on
When it shuts down, does the engine sputter and die or just turns off?
What parts were tossed at it?
Also do it have a tachometer? If it does, then watch that tach when it shuts down, if the needle is reading RPMs till stall then problem more likely fuel related. If the tach dead lines out at 0 rpm then problem is electrical related.
If you don't have a tach, then it makes it little harder to diagnose.
What I found on my 89 F250 when it did same as your problems the tach went to 0RPM while engine was coasting down. I found the EEC power relay was my problem. Took over a year to figure it out as soon as I tried restarting, truck would run for XX amount of time then failed. There were no ECU codes either.
Maxwelk9
02-17-2006 10:25 PM
