7.3 tensioner replacement nightmare
So the tensioner went out on my 95 f350 7.3. Oem tensioner lasted 309,000 miles. Bought a new one from napa didn't fit called and verified part and it was correct. It only had one alignment pin and was way too small of a tensioner. Returned. Bought one from autozone. Arm was way too long and tiny pulley. Alignment pins were in wrong spot wouldn't slide all the way into the hole, arm with pulley hit mount casing on engine. Returned part. Advance auto had the same issue auto zone had. Oriellys part fit perfectly but the idler pulley won't go back on cause it hits the tensioner. I've searched all over for this issue and can't believe nobody has had this problem. Just about ready to pony up and buy a ford tensioner at $174!!!
Consider converting to the SuperDuty belt and tensioner. It is a huge improvement.
Here's my threads on the issue:
https://www.ford-trucks.com/forums/1...questions.html
https://www.ford-trucks.com/forums/1...oesnt-fit.html
Here's a related thread:
https://www.ford-trucks.com/forums/1...r-pulleys.html
Took the old one to the store all the other times besides the first. All the stores said the tensioner has been redesigned for better reliability. Well they don't fit so it can't be very reliable.
Don't want to do the sd mod yet. Need to get the truck out of the parking lot first and back home. Never imagined it would be this hard to change a simple part.
What aftermarket tensioner fits this truck. Part #?
boots6868
07-23-2015 09:43 AM
Spktyr
23
06-17-2012 01:47 PM
93RangerXL4x2
03-06-2011 07:26 PM
blacklab1
01-18-2011 10:11 AM
dakotajeep
10-09-2007 11:05 AM
