List of item needed for 302/AOD swap
Old 07-04-2014, 08:54 AM
66f100tx's Avatar
66f100tx
66f100tx is offline
I have been looking for a "check" list sort of thing to show what someone needs to do a complete 302/AOD swap into a 48-50 F1. There are tons of various posts but can't seem to find all the information in one place. Does someone have a list they can post?
I already have a 302 out of a 1977 Bronco (has rear sump)
I have a AOD out of a 82 ???
Old 07-04-2014, 10:28 AM
Wayne Waldrep's Avatar
Wayne Waldrep
Wayne Waldrep is offline
This should be a good thread so I'll subscribe.
Old 07-04-2014, 04:27 PM
carnut122's Avatar
carnut122
carnut122 is offline
Old 07-04-2014, 04:42 PM
66f100tx's Avatar
66f100tx
66f100tx is offline
Thanks for posting that but most of the links are for EFI stuff. I have a carbed 302. I guess was hoping for a checklist type list. I love FTE but a lot of the postings get mixed up and a lot gets lost in all the postings. I have spent hours researching the subject. I lot of guys say "don't do this" or "do do that" but they never say what the reasoning is for this position. Also, a lot of the posts reference getting a certain part but never give what part # they are talking about. Simply saying "oh, NAPA has that" but they never say what it is. Don't mean to sound negative just think it would be better with a sticky checklist. Thanks.
Old 07-04-2014, 04:56 PM
teardropty's Avatar
teardropty
teardropty is offline
I can understand a bit where you are coming from. When I first joined FTE many people referenced old articles and posts that suggested items that haven't been in production or readily available for years. Having said that, FTE, as I am sure you would agree, can be an awesome place for reference and knowledge. Having said that, I will start out by giving an outline of the parts and pieces and someone with more knowledge can maybe fill in the blanks.
Radiator
Coolant hoses to/from radiator and most likely heater hoses
Fuel Lines and fuel pump w/filter
Engine (302 in this case)
Carb
Carbed Intake
Exhaust Manifolds/Headers
Complete Exhaust System for a V8
New Mounting brackets to frame for engine
New transmission bracket/mount
Starter
AOD transmission
Torque Convertor
Lokar or similar floor shifter
Driveshaft
Hope that helps
Old 07-04-2014, 06:10 PM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
There's also going to be flex plate, torque converter matching as well as a Lokar (or similar) ATV cable and it's adjustments. Drive shaft will probably need shortened and you'll need the AOD yoke too.
I agree that postings never seem to end with a list telling you to do this and that's all you need to do. But one of the problems is every truck is different. If they told you to cut 4" off your drive shaft and then yours was too short
I've had best luck seeing a post and then PMing the FTE member and asking questions.
But now that you've opened the can of worms we'll be looking for your checklist.
Old 07-04-2014, 06:26 PM
ChuckRob's Avatar
ChuckRob
ChuckRob is offline
Their are a lot of the guys on this form that have done the 302/AOD conversion. We all started on the same path but took different roads to get to our final destination. Their are just to many options available to come up with a recipe, like in a cook book, for this conversion. There is probably no two trucks on this form that uses the same parts list. Budget, bling, performance, cool ideas and the previous owner will all come into play. Teardropty's list is about as good as your going to get.
Old 07-04-2014, 07:13 PM
carnut122's Avatar
carnut122
I guess I missed that it was out of a 1977. You'll have an easier time with the carb.
Old 07-09-2014, 06:18 PM
66f100tx's Avatar
66f100tx
66f100tx is offline
Thanks that is what I was looking for... one other question -
When I picked up my 302 the other day, I had oil running out the pilot hole area of the area (like around the crankshaft) . The motor doesn't have a flex plate or transmission attached. Is that normal for oil to run out there? Sorry if its a stupid question.
Old 07-09-2014, 06:57 PM
teardropty's Avatar
teardropty
If your flywheel bolts where missing, then oil will dump out of the case. Remember you flywheel bolts to the crankshaft and the bolt holes run all the way through the crank.
Old 07-09-2014, 07:43 PM
carnut122's Avatar
carnut122
(...scratching head trying to remember if I put any type of sealer on them...)
Old 07-09-2014, 08:17 PM
bjmayberry2
Always better to ask and know then to assume and find out later
jlsmith37804
02-12-2012 04:54 AM
53OlderThanMe
09-08-2008 09:05 AM
55forder
03-28-2005 09:45 AM
Quick Reply: List of item needed for 302/AOD swap
