Balance Shaft?
Old 07-08-2014, 11:05 PM
Stricklr's Avatar
Stricklr
Stricklr is offline
Balance Shaft?
Hello to all
I have been lurking for awhile. Just encountered a problem. I have an 06 ranger with 4.0. Replacing the timing chains and every diagram even aldata shows a motor with the balance shaft. Mine does not have the Balance shaft. Having trouble finding new Jackshaft and crank pulley bolts. They are torque yield bolts and can't be reused correct?
Thanks for your help
Old 07-09-2014, 05:22 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Welcome to FTE. I moved your post to the correct forum and started a thread with it.
Old 07-11-2014, 04:24 PM
reddog99's Avatar
reddog99
reddog99 is offline
When I first got my 2004, I got the factory shop manual and it showed the balance shaft only on the 4WD model. It always puzzled me as to why only the 4WD got it, but I've never found the reason. The manual didn't go into much detail about it.
Old 08-05-2014, 04:43 PM
Stricklr's Avatar
Stricklr
Stricklr is offline
Never got an answer on the balance shaft motor. My truck is 4WD. Ford dealership didn't have an answer.But all is well got the motor back together and it is running well. Very quiet with no chain rattle.
Thanks
Stricklr
reddog99
03-19-2024 01:00 AM
Space Truckin'
09-11-2022 07:01 PM
RabidJade
03-30-2010 08:09 PM
jolinbrown
Bronco II
18
03-18-2008 01:28 PM
92 f150300six
08-08-2003 04:32 PM
Quick Reply: Balance Shaft?
