Scan tool reads bank 2 fuel sys. N/a?
i have a 2004 ford f350 6.8L V10 and its running lean once i hook up the scan tool it shows fuel system 2 as N/A and the o2 sensor on sensor 1 bank 2 shows 0.000 ive replaced the oxygen sensor and still same issue i dont know what else to do also theres no check engine light on where do i go next and why would there be o signal reading on the sensor by the pcm?
Model: F350
Year: 2004
Will you attempt to fix yourself?: Yes
What have you tried so far?: plugs, coils, maf sensor, o2 sensor, all injectors are firing the right way and pressure is great.
Model: F350
Year: 2004
Ok so do you have any idea what to do next? I'm out of options as far as my knowledge.
is the vehicle running poor any other trouble codes repair history. sounds to me like the scan tool just is displaying the data in a very basic level o to one volt scale real way to test it is not with a auto parts store scan tool what kind are you using lap scope / scan tool or live data code reader. you can test them but sounds to me if nothings wrong with the vehicle this information is fine so any performance issues. do you have lean codes
a genetic one gives codes and definition runs live data etc. i have used it to work on hundreds of vehicles i have never had an issue on accuracy with it with that said i can throw the damm thing away no problem but doesnt change the fact i have the original issue on my truck there are 0 codes stored / history or showing the engine light comeson normal prior to starting the vehicle so that is working properly also i can get it to throw a code if i want to by unplugging the MAF/INJECTORS/COILS ETC but it wont tell what the heck is wrong with it as far as the rough idle/driving condition i came on here for some advice on where to go next with my truck as far as diagnosing it but it seems that everyone is stuck on my scan tool not giving me the answer if the darn thing did i would be posting it on here and wasting anyones time
live data states +20% short trims on bank 2 long trim -20% that's how i know its running lean. next question is hood is aftermarket so there's no sticker under the hood but its not a California one that's for sure. what i'm getting hung up on is reasoning for it running lean is bank 2 oxygen sensor is 0.000 is not suppose to read 0.000 also the bank 2 oxygen sensor fuel system reading is n/a ive never seen that before so did i replace the sensor yes do i know its a AFR YES if it weren't Afr it would make any changes to the AFR on bank 2 and it would be running perfectly fine as the bank 1 is sensor is reading 0.458 to 0.658 the last 2 numbers on that are just out of my a== but that sensor is reading fine also fuel system bank 1 oxygen sensor show that is working not N/A like bank 2
does it happen when the engines is cold all the time. try plugging the suspect sensor and see if the problem still exists. i do not mean your scan tool is bad but for this type system it was never meant to take these readings and just so you know their is a big difference between an air fuel senor and a oxygen sensor they are different did the sensor have many little hole or no visible holes in it. did not mean to side track but its very nice that you know the fuel trims. and do you have a fuel pressure gauge and propane bottle. and what makes you think you have a lean condition.
do you know what an oxygen sensor is. do you know what an air fuel ratio sensor is. whats the question. you have a narrow band type sensor and a wide band type sensor an oxygen sensor makes it own voltage were as an air fuel is much different its much more precise then an oxygen sensor. does not matter any way this will not aid him in diagnostics but for that same reason he was hung up on the sensor readings. one last thing these trucks should be stock with narrow but with the odd readings he was getting it does not much matter.
If the truck is OBD1 (most likely) then it is probably using PCM data storage locations other than where your scan tool is looking. Since the scan tool is looking at PIDs that are either undefined or the incorrect one for your particular vehicle under test, the tool is reporting either N/A (not available) or a zero value.
narrow band voltages are much different or the opposite of a wide band sensor. the narrow band sensor reads on a zero to 1 volt scale were as the wide band has a wide range of voltages that climb the opposite direction depending upon rich or lean condition but wide band sensors monitor the exact air fuel ratio not just rich lean based on oxygen content. they are both listed as oxygen sensors but really an oxygen sensor can be tricked an air fuel measures air fuel it does not go off one or the other it gets a voltage signal and changes it does not create it. the point was if he had an air fuel set up which is not stock this would make his reading completely different. all it is precise tuning of the fuel mixture which a typical narrow band does not have.
