Acccumulator vs. Drier
on
Accumulator took place of the reciever dryers from years ago. just about everything on the road has an accumulator on it. witch is nothing more than a chamber were excess oil is stored and a desicant bag which helps pull moisture out of the system. you need to find out if this is a factory installed air, an aftermarket system installed by the dealer, or a system installed by someone else, there should be a sticker under the hood that tells you what you have, you could also have a mid year break were they changed some parts, make sure you give them the production date when you order your parts.
f150blues
20
07-26-2017 12:21 PM
76Hauler
10-04-2008 04:18 PM
