I think you'll find that 2 on each side are dead. This is because one circuit in the carb is clogged. At least that was it when mine started running on 4.
See if they are front and rear cyls on one side and 2 middle ones on the other side. The wet plugs were getting fuel, the dry ones, not. I kept thinking ignition at first, but it was carburetion. Follow the runners in your intake manifold. They tell the story.
