I'm having a problem with the A/C in my 2005. It started blowing warm air in normal mode. If I switch to recycled air it blows cold air. I found the compressor runs in recycle but turns off in the normal mode. hoping somebody had this problem before or has some idea why .
If the compressor works in the normal climate control modes but does not only in the MAX A/C mode, the only thing it can be is either the switch (if a manual control) or the EATC (if equipped) as 1saxman alluded to.
