A/C question
Old 07-01-2014, 10:28 AM
lowrider50's Avatar
lowrider50
lowrider50 is offline
A/C question
I'm having a problem with the A/C in my 2005. It started blowing warm air in normal mode. If I switch to recycled air it blows cold air. I found the compressor runs in recycle but turns off in the normal mode. hoping somebody had this problem before or has some idea why .
Old 07-03-2014, 01:53 PM
1saxman's Avatar
1saxman
1saxman is offline
Probably will need to replace the head unit (the HVAC control unit in the dash).
Old 07-09-2014, 05:26 AM
RangerFL1's Avatar
RangerFL1
RangerFL1 is offline
Wire needs to be check, There might be some loose connection
Old 07-09-2014, 07:47 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
There's no wire to check.
If the compressor works in the normal climate control modes but does not only in the MAX A/C mode, the only thing it can be is either the switch (if a manual control) or the EATC (if equipped) as 1saxman alluded to.
Wayne J
1997 - 2003 F150
05-27-2017 05:03 PM
Tedster9
1983 - 2012 Ranger & B-Series
07-18-2016 09:42 AM
rebelford11
1999 to 2016 Super Duty
03-01-2006 07:20 PM
seanboy
01-17-2003 10:55 AM
Quick Reply: A/C question
