new rear axle seals leaking gear oil. What could be wrong?
Old 07-09-2014, 07:35 PM
Leatherneck007's Avatar
Leatherneck007
Leatherneck007 is offline
Originally Posted by nicksorenson
Cleaned the vent tube (plugged solid) and so far it seems to be ok!! Very happy about this! No seal change yet (with the existing NAPA seals). So it looks as if the plugged vent was the problem. This is in a E350 (Dana 60) but I believe the hub/spindle seal is the same as on other rear ends.
Where os this vent tube located?
Old 07-09-2014, 10:30 PM
nicksorenson's Avatar
nicksorenson
nicksorenson is offline
It's (on the Dana 60 in a van anyways) on the driver's side center of the axle bore. It looks like a piece of fuel hose coming up out of the axle bore and there's also the rear brake line T in the same area.
Old 07-10-2014, 04:30 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
NO, a Dana 60 is way different than the Sterling 10.25 found in pickups
Old 07-10-2014, 08:26 AM
nicksorenson
I know the axles and differential are much different... wasn't talking about that. I was talking about the spindles and hubs including seal. I don't have a pickup, but from what I've seen reading around on forums I believe the trucks look similar to what I have:
-8 -- 14mm bolts holding the end of the spindle (free floating) to the hub
-splined spindles that pull out
-under that a ratcheting nut that requires a special socket to remove/install
-The hub (drum or disc on later models) has a press in lip seal on the rear to seal it to the spindle and hold in the gear oil
Where is the vent tube on the trucks (Sterling 10.25 or 10.50)? Is it not between the pumpkin and the drivers wheel (coming out of the top of the axle bore)?
Old 07-11-2014, 03:57 AM
Diesel_Brad
With the e-series Dana 60, do you have to remove the axle shaft to remove the drum like the earlier ones found in pickups, or does the drum slide right off after a tire removal?
Axle vent is in drivers side axle tube
Old 07-11-2014, 07:46 AM
nicksorenson
Axle vent is in drivers side axle tube (what was mentioned in my earlier post). Also on this unit the drum comes off right after the rim is removed (no need to pull the spindle). But the hub does not come off without pulling the spindle of course.
I get the impression (called a Dana supplier) that the hub assembly is a Ford part (not Dana). So I figured it would be the same regardless of Sterling or Dana axles. But not owning any Sterling equipped vehicles I could be wrong. Seems like pictures I've seen of trucks (pre disk) also seem to look like what I have regarding wheel hub/seal/etc.
Old 07-11-2014, 01:13 PM
Leatherneck007
So how do o tell what axle is on my pickup? Sterling or dana or ford? The napa guy said ford when he looked at it to get the correct seals. Ford 10.25.
Old 07-11-2014, 01:17 PM
nicksorenson
Look in your door for the tag. It gives the axle code. Then you can look it up.
But for the most part the trucks have the Sterling 10.25 or 10.5.
Old 07-11-2014, 04:13 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
OBS trucks have a sterling 10.25. Super duties have a 10.5.
Old 07-12-2014, 06:35 AM
Diesel_Brad
....... So I figured it would be the same regardless of Sterling or Dana axles. But not owning any Sterling equipped vehicles I could be wrong. Seems like pictures I've seen of trucks (pre disk) also seem to look like what I have regarding wheel hub/seal/etc.
You would be wrong. Dana parts and sterling parts do NOT interchange.
You have a sterling 10.25 because all 3/4, & 1 ton pickups from 86-97 used them exclusively
Old 07-12-2014, 10:19 PM
Leatherneck007
ok thanks guys. I love this forum. you guys are awesome.
quakerj
12-20-2014 10:24 AM
cowboy117
02-08-2011 02:16 PM
pgjeepster
1999 to 2016 Super Duty
11-20-2010 06:13 PM
stupidtruck
06-20-2008 09:47 AM
02superstroker
03-02-2006 05:11 PM
Quick Reply: new rear axle seals leaking gear oil. What could be wrong?
