Cubic Inches
Old 08-26-2014, 01:16 PM
mtntop1's Avatar
mtntop1
mtntop1 is offline
Cubic Inches
If I bore a 302cu in .30 over what will the new cubic inches be. Also approximately how much torque improvement.
Old 08-26-2014, 02:06 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,644 Likes on 1,340 Posts
That gives you a 306 and probably no measurable difference in power. You gain 4 CI, but you lose just a tick of compression.
Is this just a clean up bore during a rebuild?
http://www.wallaceracing.com/cid.php
Old 08-26-2014, 04:46 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
Wouldn't boring out the cylinder GAIN a tick of compression? It's squeezing a little more volume into the same combustion chamber.
Old 08-27-2014, 12:40 AM
85e150's Avatar
85e150
Bigger space and VE is not 100%. Marginal VE is even lower. Plus you usually have a bigger head gasket gap.
Old 08-28-2014, 11:07 PM
SDDL-UP's Avatar
SDDL-UP
SDDL-UP is offline
Yes, you gain compression by increasing the bore.
Old 08-29-2014, 12:39 AM
85e150's Avatar
85e150
Checked a couple of static CR calculators. You are correct, you get a bit of a boost in CR with a bigger bore, all else being the same.
Dynamic compression....not sure, but given the marginal volumetric efficiency, I don't see how you gain cylinder pressure while running. I suppose there is a standard, known calculation for that as well, but I don't feel like looking it up and proving myself wrong again.
Op hasn't been back yet.....
jonezzzman
11-19-2013 12:20 PM
econoshorty
09-06-2010 11:24 PM
rusty70f100
28
11-08-2005 10:25 PM
Annihilator
26
03-03-2005 05:45 AM
debestuss
16
09-22-2004 07:52 PM
Quick Reply: Cubic Inches
