Stage II, finishing my project F-150
#31
I forgot to get after pics
will post after pics later hoses both back to gether now though
bolts cost 140 bucks
wood was about 70
steel 71 bucks
sleel is bolted down good
ready for the planks
Bought3, 6 foot pieces of 4" steel channel this morning, cleaned with solvent, and gave them a couple coats of spray paint. got them secured down good and hooked up the gas line filler hoses. For now, I plan on getting brand new hose and even brand new locking caps.
#32
got rained out
I ll scrub these in place with a green scrub pad, at least try to clean it up a bit.
this filler hose was originally the back one, reversing them made a pretty good fit
but got quite a few holes drilled . still have a lot to do. Some pics of how I hooked up up the gas tank filler hoses.
#35
#36
#40
If you trim your outside boards a little bit you could still add some metal around the outside if you wanted later.
#41
Gary Lewis, you can sort of see the 1/2 inch hole in the channel for an anchor point for a strap hook for now
Filler hoses kinda look like they belong there.
Thanks guys ,
Franklin , that's pretty close to what I'm planning. lots of add ons but this is budget right now, this was close to 400 bucks so far.
Done, this part of it anyway, still need to go to princess auto and buy some tail lights. Going to back it out from beside the house later today when there is nobody home next door, wink emoticon
#42
I know it will be tough to do, but if you spend the money for taillights now, can you get ones that will work for you in the final version?
What I am thinking are the ones with the rubber around them that the 18 wheelers use. I just helped with a larger truck and a custom flatbed, and we used a piece of diamond plate in the rear, with holes cut out for the lights to fit inside.
I think in the final version yours would look better if you got rid of the stock bumper, put a piece of diamond plate, either aluminum or steel back there, and install a reciever hitch on the frame.
#43
#45
Wet sanded once over quick with 400 on the block sander. rinsed her down a bit and after another trip to princess auto I got everything I need for the tail lights, got two on will do the other two tomorrow, I have to carve out the wood a bit to make them inset.
Went with the LED's as you can see.
