later model (93 on) 7.5 oil pan gasket is a 1 piece rubber gasket. Only issue is the corner bolts on the earlier blocks were bigger and that gasket has gromments that are setup for the smaller bolts. Not a huge issue you just have to carefully cut them out.
I found a one piece rubber gasket from jegs, milodon brand, that has the right size holes for the older block. I hear there are a couple spots that I still should silicone when I install it, sound accurate?
