Has anyone converted their cigar lighter to a power port for charging phones and such? I saw a port at the zone but package listed not to be used to replace cigarette lighter. Any ideas?
I think they just meant people shouldn't buy it if they want to keep the lighter feature. There are no fingers in a power point to hold the lighter in there to heat up. If you don't smoke,you can put the power point in.
The PO of my '70 converted it. The OEM port and cigarette lighter are in the glove box. I'm not sure what brand it is but it has a convenient rubber cover to protect it when not in use.
I like mine having the lighter. I keep it there so it looks like it should. The lighter part doesn't work and I would like to find a replacement eventually. I use it as a power port when I need to charge things but return the lighter after.
I'll look when I get home Greg. I think I got one.
Didn't think about putting the port in the glove box that's a good one. I need to replace the glove box insert anyway because when I attempted to remove it it fell apart from water damage. I thought about making one from a lightweight metal but the old school paper ones are pretty cheap.
anyone know what kind of amp rating the stock cigar lighter circuit is rated for? wondering what all can run off of it without overloading it. something good to know while on the trails incase any power is needed if your in a bind.
thanks 351, i haven't done a 3g swap yet as my engine plans keep changing. but i'm planning on one with my 460 in my 66 f250 but my 71 f250 shouldn't have any trouble running tools or other stuff on a power port with a 12v diesel alternator supplying the juice
Lemme clarify.. the PO disconnected the OEM port and lighter and baggied it. It was stored in the glove box for safekeeping.
