BossFan's '78 F250 build
#181
#182
#183
#184
#185
#187
motor mounts
On a separate note, were the motor mount brackets painted or left bare steel? Also, what motor mounts should I get? There was no 351W in a 1978 F250. Do I get ones for a 302?
Also, I want to remove the shocks but when I turn the 9/16 nut, the whole shock spins. I tried holding the top with a 1/4 in. wrench, but that snapped. Is there a trick here?
#188
See the crimped in sides on the very top?
#189
Harbor Freight cost, Harbor Freight quality...it should last for at least 4. So you did not ck out renting the ball joint/u-joint tool kit?
Bare steel covered with grease, and or high temp rattle can black. Mounts ideas to follow, after research.
What snapped? The wrench, the tip of the threaded part or did it just strip? Do you need to reuse them? No sawzall, yes, strap wrench.
Look at the top of the shock, under the mount bracket, is there a nut like "fitting" that a open end wrench will fit on, at the top of the shock body?
#190
http://www.summitracing.com/search/d...-block-windsor
Reading time...Ford Ranger V-8 Engine Swap
Lots of good 351W info here... Keith Cauley's 351 swap faq's | The go fast for cheap home page
Everything I read is yes on 302 mounts and they are L and R specific.
http://www.wcb4x4.com/mm5/merchant.m...egory_Code=ENG
#191
I got the shocks off using an impact gun and removed the shock towers. I also pulled the steering box. Where the shaft attaches to the box just fell apart. I imagine that was one reason for my sloppy steering.
I cleaned up everything as best I could, including the mouse nest that was inside the frame. Would you recommend painting this part of the frame with POR-15 like I did the rear? There isn’t as much rust up front (I think the leaking oil over the years kept everything well coated)
I still cannot get the crossmember out from under the truck.
#194
#195
$ well spent ck out Redhead steering Red-Head Steering Gears - Custom Rebuilt Steering Gear Boxes in USA
Borgerson steering shaft Borgeson Universal Company :: Ford Truck 1970-04
Wow you have some rust on that truck.
