BossFan's '78 F250 build
#121
Those upgrades on the dana 44 are more preventative so your not in there any time soon .. If you ever go with a bigger motor or you decide to plow etc. .. In your case you probably could get by without them but on the u-joints since your in there and the price difference is less than $100 difference it just makes sense to me ..
The geometry on both the inverted "T" or cross over is just stronger and a more stable steering set up and it will hold your alignment well .. Lifting the truck gives you a chance to upgrade the springs and get rid of the blocks giving your truck much better road manners and ride ability .. Going with a variable rate/progressive spring brings the suspension into the 21st century ..
Crossover
High steer inverted T
Crossover
Is there a rough estimate on what it would cost to lift the truck and put in the crossover steering? The one 'JackIt' site had a 4" lift kit for $1700. Is that the going rate? How much is the crossover steering kit?
#122
D44 info and a tech tip.
If your Jeep has half ton internal hubs, chances are you have the three piece spindle nuts. The inner nut sets the tension on the bearing, the lock washer slides down the slot on the spindle and a pin on the inner nut goes in a hole in the lock washer, and the outer nut holds it all in place. Sometimes, you get lucky and that lock washer slides right down and the pin in the nut goes right in a hole in the lock washer, sometimes it doesn't. Some Ford Dana 44s use a self locking spindle nut that does not require aligning the pin and makes installation much easier.
If you have the 3 piece Jeep spindle nut, a good trick is to try the lock washer and if it doesn't line up, flip it over and try the other side. The holes are lined up a bit different when the lock washer is flipped over. Often this will do the trick, but sometimes nothing seems to work. Especially, if you are trying to fix a broken axle on the trail.
The Ford spindle nuts eliminate these problems. The Ford spindle nut ratchets down and locks on every click. You can set the perfect load on the bearing with no worries of aligning the pin. You have to press in on the spindle socket to engage the teeth in the ratcheting nut. Works a bit different, but easy enough.
The only down side to the Ford nuts is the cost. They run about $15.50 brand new at the Ford dealership. The jobber price is probably a lot better than that, but most of us ,like myself, have to pay retail. It probably is not too hard to get the nuts at the junk yard, but to save time, I just purchased two nuts brand new at the dealership. My local dealership had them in stock, so there was no waiting. When I went to the dealership, I asked for the nuts for a '94 Ford F-150. I got that make and model from a tip from Dave on our Jeep Forum. I'm not sure what range of vehicles they might have been used in. The Ford part number is E7TZ-1A134-A.
One thing I had to do with the Ford spindle nut is remove some material on the tab that slides in the slot in the spindle. I guess the Ford spindle has a wider slot it it. I did this with an air cut off tool, but a file or a hack saw would work.
#123
Thanks Rich! I got to the point of realizing I needed that special wheel-bearing tool last night. Was able to remove the locking hub, the two snap rings and the assembly, and then realized I needed that 4-prong tool to go any further. Is that something that would be available locally or do I have to order that?
#124
Jackit....about the worse place to start looking for lifts, IMO.
Here are a few that sale off the shelf stuff.
Skyjacker, Superlift, Rough Country.
Progressive rate springs... Atlas Atlas Suspension
Deaver....http://www.deaverspring.com/
Cross over...Sky manufacturing, Ruff Stuff
Ford - all - www.sky-manufacturing.com
Off-Road Fabrication Parts - RuffStuff Specialties
#125
That socket is usually in the special tool dept at the local parts house, for 10 to 12 bucks, places like Auto Zone, Napa ect...could look into renting the ball joint tool kit its like $$ to buy.
With a punch and some patience, it can be take off, but a socket ensures no damaged lock nuts.
#126
Are you taking notes, digital pics? Putting parts in order that they come off. Tag and bag hdwr, or but back in the hole it came out of on brackets and parts that come off.
Stick stuff in a cardboard pattern, works great for a water pump bolt layout cause some are at different length on a 351M.....just saying.
Things can get fuzzy come back together time.
#127
On the cross over you will have to have the passenger side knuckle machined probably $175.00 with shipping unless you have it done local .. Talk to your local chapter guys for recommendations .. The kit should be $400 - $600
Dana 44 Crossover Steering Arm
Once your knuckle has been milled and tapped, this is the arm to make it crossover.
$119.99 ..
Studs are $5.99 each
You will still need the drop arm and your cross links but those are the basic parts .. You can find kits or piece together what's needed .. The 4X4 Store - Steering .. There's plenty written on the subject here at FTE ..
#129
#130
#131
If I go with a lift, is this what i want? Dana 44 Crossover
#132
What are these bolts for?
Also, if all I wanted to do was change brake rotors, would I still have had to disassemble the entire locking hub assembly and purchase the special wheel bearing tool? I saw that some online retailers sell a completely assembled hub and rotor. Do you have to disassemble that to install it, or is there a way to take off the entire hub/rotor assembly?
I think you can see from all the rust, that I really need to freshen up this front end. It might be easier to just find another front end that was already rebuilt.
#133
What are these bolts for? The insert is welded in the ends of your cross tube and the heim joints (bolts) are threaded into them and the lock nuts do their job .. One each per tube end .. They take the place of the tie rod ends and are a stronger set up
Also, if all I wanted to do was change brake rotors, would I still have had to disassemble the entire locking hub assembly and purchase the special wheel bearing tool? Yes see here
I think you can see from all the rust, that I really need to freshen up this front end. It might be easier to just find another front end that was already rebuilt. Yes that is true but you would not know for sure the quality of the work and what parts were used internally .. A power washer will knock off a good portion of it and the remainder take a drill motor and a steel cup brush to it ..
#134
So I removed the pan tonight and I'm not sure if my rear main is leaking, but it does look like the rear corners of the pain were loaded with RTV gasket maker. I would use a one-piece pan gasket when I put it back together. I'm guessing I should still pull the crank?
You can also see the broken bolt in my crankshaft. Grrr....
#135
redroad I think he meant the bolts in his front end pics, they are steering limit/stop bolts.
Good read on the front end disassemble, redroad.
Yes you have to take the hub and rotors off together, as they are one piece (actually they are 2 separate pieces, but they come off the front end as one.
On a 1/2 ton the front rotor just slips on over the hub, separate from the lugs bolts. But with a 3/4 ton they are one. Once you take the complete assembly off you can tap/press out your lug bolts to separate the rotors from the hub.
Yes they sale just rotors $ and or a complete assemblies (hub and rotor) $$$. Just get the socket, you will need it come re-installation and torque time anyway.
One you have the hub/rotors off and get the knock in back side axle seal out and removed the inner bearing and get it all cleaned up and then insp your races, and make the call to replace the complete unit$$$ or get new bearings that come with races and tap/press out your old races and tap/press in your new.
Just clean up what you have, its doable with some work.
