2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Oil Life %
Old 06-18-2014, 06:46 PM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
Oil Life %
Does anyone know if the oil life is just calculated straight off the odometer, off some combination of odometer and type of driving (speed) or if the vehicle is actually monitoring some attributes of the oil?
Old 06-18-2014, 09:49 PM
montecarlo31's Avatar
montecarlo31
montecarlo31 is offline
If I am not mistaken it is based off:
Start Cycles
Miles
Idle Time
% load
I notice when towing or lots of idling the % changes at a faster pace than just running down the highway.
Old 06-19-2014, 05:43 AM
alwaysfords41
Thanks. It is interesting because with my wife's 2010 her usage calls for a change around 4k miles, which is my interval anyway. I just went to do the first change in my 2012, and at 4k miles the indicator said I had 42% left.
Old 06-19-2014, 02:10 PM
07EXPYEL's Avatar
07EXPYEL
07EXPYEL is offline
5000 miles or 180 days for 2007 model year. Your %life will decrease if you don't drive it much. We only drove ours 8K miles one year and the life would tick down even when not used. I think 2008 and after are 7,500 miles for oil change.
Old 06-19-2014, 05:22 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
According to my owners manual its based on mileage and time.
100% life would be 7500 miles or 6 months ( per manual 08 MY )
There is no mention of idle time, start cycles, load etc....
I usually reset one of the trip meters when I get an oil change and it pretty much matches up exact to the mileage interval.
The mileage interval can be changed to less than the default of 7500 miles. If you set it for a start value of 60% it will equal 3000 mile changes.
Matt
Old 06-19-2014, 06:24 PM
montecarlo31
Matt
Why would you change it at 3,000 miles?
Old 06-19-2014, 07:00 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
??? Not sure I understand your question.
If you mean why would I change the oil at 3000 miles ??? I wouldn't, it was just the example used in the manual.
If you just go by the factory default setting the oil life/ change reminder is going to come on approx. every 7500 miles saying oil life is 0% and it's time to change your oil.
But for example, if you like to change your oil ever 5000 miles you can change the reminder to come on at 5000 mile intervals by adjusting the oil life starting point. Instead of it starting at 100% you would start it at like 80%.
Matt
Old 06-25-2014, 02:48 PM
mpgo4th's Avatar
mpgo4th
mpgo4th is offline
I also have an 07 EL and my monitor let mine go to 6000+ miles before saying change oil. Mine is driven mostly open road with very little stopping.
Truckpilot1329
2009 - 2014 F150
55
12-19-2019 07:37 PM
Horsehaulin8
2017+ Super Duty
02-24-2018 10:59 AM
wfedwar
2017+ Super Duty
21
07-07-2017 09:38 PM
wolf189
2004 - 2008 F150
01-30-2011 06:54 PM
carpe_diem
Oil & Lubrication
07-13-2003 02:18 AM
Quick Reply: Oil Life %
