How much horsepower does a stock 7.3L have???
#62
The granite would last forever, but your hands would be dry, cracked and bleeding after a few hrs of that stone sucking the moisture out of your skin. Personally, I prefer the one in my Lariat more than the one in my XL. The rubber gets kinda sticky and no matter how much you clean it, it feels gross. I think is be finding a nice cover if I was in the market.
#63
I'm looking around online this morning for ODB II scan tools and I came across a forum. That stated the f350 IS NOT ODB II compatable. Does the same go for the F250?? I got a 1999.5 F250.
I was looking at this ScanGauge II - Scan Gauge OBD II Scanner - OBD2 Scan Gauge
or
or
#64
#65
I wasn't sure I'm learning as I go the only way to learn.
After looking around some more I want some thing that runs off my laptop so I'm think AutoEnginuity. It does everything and more then I need you never know that your going to need.
Here is one on Ebay
http://www.ebay.com/itm/AutoEnginuity-OBDII-OBD2-Windows-Scan-Tool-Scanner-USB-/301229697688?hash=item4622b06a98&item=301229697688&pt=Motors_Automotive_Tools&vxp=mtr .
I know nothing about what is supposed to come with these there website doesn't show( AutoEnginuity) I would imagine a disk. Or even if this thing is old. It says refurbished.
Here is one on Ebay
#67
#68
The 7.3L PSD is OBD II compatible, but it is not OBD II compliant.
Stewart
#69
#70
You didn't misspell the word. Our trucks are OBD II compatible. You can hook up any OBD II scan tool/reader/gauge to the OBD II port because it is compatible. The tool may not read everything unless it's a higher-end scan tool or gauge though.
However, even though our 7.3's have OBD II ports, and they are compatible with OBD II tools, they are not OBD II compliant. What that means is, because our diesel rigs aren't OBD II compliant, they don't have any emission standards they have to meet, PCM wise.
Stewart
Side note: This is how I explain the difference, based on my experience and what I've read, and how others have explained it. This is not based on any direct fact that I can point you to on the 'net.
#71
#72
Emissions are not only based on where we live (or where truck was first sold), they are also based on time (when truck was first sold) and engine (what truck was first sold with). However, within any given year of truck, the location of wiring, data port, and PCM are more or less the same. In this case, the OBD-I trucks use the same PCM, J1850 serial data communication link, J1962 Data Link Connector, and PCM software as the corresponding OBD-II trucks.
If a truck is not required to comply with OBD-II requirements, it utilizes an OBD-I system. OBD-I systems are used on all over 8,500 lbs. GVWR Federal truck calibrations. California OBD-II applies to all diesel engine vehicles up to 14,000 lbs. GVWR starting in the 1997 MY.
"Green States" are states in the Northeast that chose to adopt California emission regulations, starting in the 1998 MY. By 1999, Massachusetts, New York, Vermont and Maine were Green States. Massachusetts and Maine received California Certified vehicles for passenger cars and light trucks up to 14,000 lbs. GVWR. However, in 1999, New York and Vermont received California Certified vehicles for passenger cars and light trucks only up to 6,000 lbs. GVWR.
#73
If MA adopted the CA laws and received CA emissions from 1998 MY fwd then wouldn't my MA sold (always registered in Ma even with Prev owners) 2001 have a GPCM vs. the GPR? My buddies 7.3L Excursion (since sold) was a NH and did have the GPCM on a 2000 I believe.
Or could they have the CA emissions with a GPR? Or of course less likely, but possible someone could have swapped the GPCM for GPR in my rig.
#74
The resources (Ford's PCED) I relied upon to answer bobiker's question covered a broader scale pertaining to all trucks, gasoline and diesel. Since bobiker has and was referring to a 1999 model year, the trick was making sure to reference information only relevant in that model year, as the laws and various state's adoption have changed in the decade and a half of time since.
As for the presence or lack thereof of a glow plug control module in your MA truck, it has always been my understanding that those modules were on all Excursions and only California 7.3L trucks, and not on 49 state trucks, regardless of what may seem like conflicting information in the PCED summary data above. The specific GPCM component diagnostics refers only to Excursions and California emissions calibrations.
Still, "California" has become short hand in vehicle parlance for advanced emissions systems in general, and some border states to California, as well as several states on the east coast, tend to have "California" emissions.
In your specific case, if your truck originally came with a GPCM, and a previous owner removed it, then your PCM would set any number of DTC's between P0671 - P0678.
