headlights ???
Old 06-18-2014, 04:02 AM
bigpetie's Avatar
bigpetie
bigpetie is offline
headlights ???
how do i remove them & put in new ones ?
Old 06-18-2014, 12:41 PM
mecdac's Avatar
mecdac
mecdac is offline
Two Headlight Retaining Clips on top of the assembly and two screws on the bottom in the gap between the bumper.
Old 06-18-2014, 04:59 PM
bigpetie's Avatar
bigpetie
bigpetie is offline
Thanks ...how do u get clips off. ?
Old 06-18-2014, 05:33 PM
mecdac's Avatar
mecdac
mecdac is offline
There is a tool that looks like a "T" (see diagram on clip). If you do not have something like that:
Take two small hex key/allen wrenches, insert the short ends in the top of the clip (see diagram on clip) so that it becomes a "T".
I used a vice grip to hold them together and pull up, be prepared to sacrifice the future use of the aforementioned hex key/allen wrench. The larger the hex key the stronger the tensile strength.
Using a screwdriver to pry will bend the clip(s) and you will have to get new ones.
SVTDarin
01-27-2019 08:03 AM
Ezalycasaid
08-07-2016 03:01 PM
mtn dew brent
12-28-2010 11:51 AM
ronnie95252
1983 - 2012 Ranger & B-Series
12-12-2006 09:04 PM
Excursion 7.3 Fan
03-06-2004 09:02 AM
Quick Reply: headlights ???
