1989 F250 Crank, No Start
If it is not kicking or backfiring do not worry about the timing right now.
Sounds like you have a fuel problem to fix before anything else.
Ground pin #6 of the self-test connector and turn on the key to run. What fuel pumps are running?
Select the other tank. What fuel pumps are running?
Flashing sequence was 8, 5, 8, 5, 1, 9, 6, 9, 6.
What I got from this was:
85- Canister Purge Circuit Failure
19- Fail in ECC Reference Voltage
69- Transhydraulic switch (THS 3/2) failed
6..? - No clue, there were an uneven amount of numbers
As far as the fuel pumps, I only have the rear tank installed. When I turn the key "on" I can hear the in-tank pump and the HP pump energizing.
Also, turning over today doesn't make that spinning feeling like it used to.
I'm sure it happens. More than once my diagnostic effort was side-tracked by the fact that the faulty part was new.
On the other hand...could be variable electrical supply to the pump or clogged lines.
Got the old pump? I would start by bench testing that one. Maybe it was bad, maybe not.
Roy
Roy
bigmike1161
13
06-20-2017 11:05 AM
LoveOldFordsInSouth
04-15-2010 10:52 PM
phils88150
04-06-2008 11:43 AM
Ford4me302
02-18-2005 06:12 PM
montangrunt
21
05-13-2004 03:15 PM
