Rear turn signals? (63 flareside)
Old 06-11-2014, 04:22 PM
n10z's Avatar
n10z
n10z is offline
Slowly working on a 63 f100 Flareside. Ordered new tailights and brackets from LMC, kind of figuring they would have turn signals in them. Not looking like it. Where were the OEM rear turn signals?
Old 06-11-2014, 05:41 PM
P38fighter's Avatar
P38fighter
P38fighter is offline
What do you mean by " turn signal in them?" The bulb is a two filament bulb to provide a low running light and bright turn and brake .
Old 06-11-2014, 06:59 PM
n10z's Avatar
n10z
n10z is offline
The after market tail lights on it now have 3 wires, the signal wire is triggered by an aftermarket turn signal (the one from LMC). The new tail lights that I ordered only have 2 wires.
I have a feeling this is going to turn into a much larger project then anticipated.
Old 06-11-2014, 08:00 PM
P38fighter's Avatar
P38fighter
I think the green and yellow is correct. The black is probably a ground for the aftermarket light. Original ones grounded through the light itself.
Old 06-11-2014, 08:20 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Upper pic: 1955/66 Flareside "shield" tail lamps. 1955/60's have FORD molded into the lens, 1961/66's were plain.
The left lamp incorporates the license plate lamp. The mounting brackets and the license lamp bracket are the same as used with the round lamps. that were used 1953/54.
LMC's aftermarket lamps are sorta similar to what FoMoCo began installing in 1967, as they incorporate backup lamps.
Old 06-12-2014, 07:43 AM
svolpone's Avatar
svolpone
svolpone is offline
Oh, that is a big "for sure", dude. you're just getting started. lol.
mannermauler
07-05-2019 11:17 AM
randydandy
08-04-2018 12:41 AM
Grandpa's66
13
07-21-2018 11:58 AM
lilrobo
11-16-2013 02:45 PM
alchemist1
06-01-2008 12:19 AM
Quick Reply: Rear turn signals? (63 flareside)
