No brake lights or turn signals
ok I've got a 66 f100 and just rebuilt the engine. My problem is that I no longer have brake lights or turn signals. I thought it must have been the turn signal switch so I replaced that. no luck. Next I got a voltage tester and found that the small fuse on fuse panel wasn't reading anything so I replaced it. not sure if this would be correct fuse or not but it still isn't getting power. The only wiring that I changed was going to a 1 wire alternator. Could this be where mynproblem is?????
ok I've got a 66 f100 and just rebuilt the engine. My problem is that I no longer have brake lights or turn signals. I thought it must have been the turn signal switch so I replaced that. no luck. Next I got a voltage tester and found that the small fuse on fuse panel wasn't reading anything so I replaced it. not sure if this would be correct fuse or not but it still isn't getting power. The only wiring that I changed was going to a 1 wire alternator. Could this be where my problem is?????
If suggestions made by other members has not solved the problem you may try checking the turn signal fuse, not sure if it would have an impact on the brake lights, perhaps more knowledgeable member can advise?? As mentioned, there's a pressure stop switch on the brake line distributer, suggest check the connections. Also check the connections at the flasher unit. My experience tracking down electrical gremlins is that in many cases the problem tends to be a poor ground.
http://i300.photobucket.com/albums/n...dFuseBLock.jpg
http://i300.photobucket.com/albums/n...WireDiagP7.jpg
So it turns out that I changed the wrong fuse. When I shined a flashlight on fuse panel I saw that the one I needed to change was bad so I swapped it out and everything works now. The switch needed to be replaced anyway it had some jerry rigged wiring and was pretty sloppy so all good. Thanks everyone for your help.
Spencerbarber
06-22-2015 03:31 PM
hasteranger
07-20-2012 01:34 PM
77f250400
12-13-2010 03:22 PM
mikeismadness
1978 - 1996 Big Bronco
04-11-2010 12:05 AM
cjben
Electrical Systems/Wiring
09-10-2003 05:16 PM
