runs how it wants too
Now my truck on some days will run great no ruff idle or miss and some days it will ruff idle die at lights and shake the truck at low rpms.
I hooked up my AE while running. No codes. Icp and hpop pressure seem all to be running In good numbers. Fuel pressure is right around 60 70. Hpops full also.
Any ideas what could cause this? if the weather holds up after work im gonna take my chip out and maybe even switch idm and com. Ive got a spare set I can try. Besides that I also have a new international cps I thought about trying. But can anyone give me some places to look?
Try dropping it into neutral, but don't hit the go-pedal. See if it holds an idle. If so, then it's _possible_ that what you're experiencing is the torque converter not unlocking sufficiently.
How old is the oil? One thing I've found is that when she gets crabby about idling, esp. dropping to idle after a high speed run, that's a sign that she's (over)due for an oil change.
Are you talking about the UVCH connectors? The outermost terminals are for the glow plugs. But if a terminal is burned, it's at least somewhat likely that the corresponding terminal under the valve cover is burned, and quite possible that it has damaged the injector terminal next to it. I would pull that valve cover and check the terminals on the gasket itself, and the wiring inside.
I believe Thomas is refering to the valve cover gaskets, not the covers themselves. You will have to check the wires inside the covers for melting, when you get them off. With the melted connector, and oil there, there is a pretty good chance you found the idle problem. The IDM is sensing a short there and shutting that bank down to protect itself.
