300 6 cylinder quits running when operating tempature?
Old 06-07-2014, 05:41 PM
Emt269's Avatar
Emt269
Emt269 is offline
I have a 1988 ford f-150 4 wheel drive that has a 300 6 cylinder that has approximately 250,000 miles on it. When its cold outside (winter) it runs fine but when spring and now summer hit when it reaches operating temp it will idle fine till you touch the foot feed then it starts acting like it starves for gas or maybe flooding sometimes. If you feather the gas sometimes will straighten out and idle again but will not pull itself. If you let it set awhile and cool down a little it will run and drive fine till it reaches operating temp again. I have replaced both fuels pumps tank and rail, fuel lines had one that was kinked in the past, fuel tank that leaked sending unit and filter while I had out. The fuel pressure regulator seems to be working and is not leaking. The truck runs fine like it should till it gets operating tempature? Any help would be appreciated. Thanks
Old 08-02-2015, 06:09 PM
Carl Swann's Avatar
Carl Swann
Carl Swann is offline
Mine does something like that...i can crank it up drive some where..sometimes 2 miles sometimes 15 or so then it just shuts off with no warning or anything..then it wont start back up until after it sits a couple hours...i think its a censor vut i dont know which one...its been at a shop and friends looked at it but nobody knows
Old 08-02-2015, 06:14 PM
Carl Swann's Avatar
Carl Swann
[QUOTE=Carl Swann;15544254]Mine does something like that...i can crank it up drive some where..sometimes 2 miles sometimes 15 or so then it just shuts off with no warning or anything..then it wont start back up until after it sits a couple hours...i think its a censor vut i dont know which one...its been at a shop and friends looked at it but nobody knows..
Old 08-02-2015, 06:16 PM
Carl Swann's Avatar
Carl Swann
need help with my 94 f150
Mines a 94 f150
Pete De Vore
04-08-2016 06:54 PM
MO351
09-09-2011 05:06 PM
Supercab
05-16-2004 01:58 PM
BigSix1
12-18-2003 04:18 PM
pcman
11-05-2003 05:57 PM
Quick Reply: 300 6 cylinder quits running when operating tempature?
